November 7, 2005, 15:59 |
whats there to discretize???
#21 |
Niklas Nordin
Rep Power: 29 |
I do not understand what the problem is. |
November 15, 2005, 19:10 |
Hi guys thank you everybody fo
#22 |
Muzio Grilli
Rep Power: 17 |
Hi guys thank you everybody for the help you gave me, Thank you Bernhard first, you always answered my questions even if my questions were quite silly.
I wrote the solver and it seems work, i have the loss of pressure in correspondance of the space occupied by the porous media... Here is the final form of the velocity equation: tmp<fvvectormatrix> UEqn ( fvm::div(phi, U) +turbulence->divR(U)+nu*(G & U) ); I did not changed anything in the rest of the solver leaving it as in the original form of SimpleFoam. may someone tell me if i should change something in the rest of the solver because of the adding of the new term in the velocity equation or I can leave as it is? |
November 16, 2005, 11:04 |
Ì think you can leave as it is
#23 |
VVqf
Rep Power: 17 |
Ì think you can leave as it is.
But I don't understand "fluid through a porous media OUTSIDE it", does it make sense? Could you explain a little bit? Did get different G in each time directory? |
December 5, 2005, 16:26 |
Hi Muzio Grilli:
Could you
#24 |
Guoxiang
Rep Power: 17 |
Hi Muzio Grilli:
Could you please paste your solver to here, And let us to study that how to solve porous question. Thanks. Guoxiang |
December 23, 2005, 12:27 |
Hi everybody,
Bernhard Gsch
#25 |
Nico Petry
Rep Power: 17 |
Hi everybody,
Bernhard Gschaider wrote: By Bernhard Gschaider on Thursday, October 20, 2005 - 10:22 am: Edit Post Sorry. With "out-of-the-box" I meant "a solver available in the OF-distribution". You'll have to write a solver yourself. One approach would be to simply extend an existing solver by adding Darcy as a source-term. In the Darcy-term there is a permeability/resistivity (whatever formulation you prefer). By using a field for that and specifying appropriate values for certain regions you can define porous/non-porous-zones. My Question: How can I define different appropriatet values for different regions? What boundary conditions do I have to choose for the interface between the porous and non-porouszone? bye nico |
January 5, 2006, 16:19 |
Muozo Grilli, please post crea
#26 |
Nico Petry
Rep Power: 17 |
Muozo Grilli, please post created.H, createG.H, createNu.H -files?
Thanks |
January 10, 2006, 09:33 |
My createG utility is very slo
#27 |
Muzio Grilli
Rep Power: 17 |
My createG utility is very slow..you'd better use the setFields utility which is very simple to use, you only have to create the setFieldsDict file which you can find in thedamBreak tutorial and specify the opposite vertices of the box or the center and radius of the sphere in which you want to define the G tensor is really simple
January 10, 2006, 12:35 |
The problem is, that it only w
#28 |
Nico Petry
Rep Power: 17 |
The problem is, that it only works, when you use blockmesh. I create my meshes in gambit and then this way doesn't work. It would be a great help for me, if you send me your createG utility.
Thanks Nico email : nico.petry@gmx.de |
January 16, 2006, 13:07 |
Hi!
I have directed permeabil
#29 |
Nico Petry
Rep Power: 17 |
Hi!
I have directed permeabilities and therefore I define G as a volTensorField. My problem is, that fvm::SuSp(nu*G,U) doesn't work for volTensorFields and nu*(G & U) does not give the right solution. I am not quite sure why. Hope somebody can help me. Thanks |
January 16, 2006, 14:02 |
Hi nico the second form nu*(G
#30 |
Muzio Grilli
Rep Power: 17 |
Hi nico the second form nu*(G & U) is the right one. You are using simpleFoam so you must choose in the right way the relaxation factors in the fvSolution file because otherwise the process will diverge and the solution will not be right.
Try diminuishing the relaxation factors. You have to monitor the residuals to see that convergence is achieved. |
January 17, 2006, 03:36 |
Thanks.
Is it possible to c
#31 |
Nico Petry
Rep Power: 17 |
Thanks.
Is it possible to calculate the relaxion factors, that will bring the right solution? Or is the only possibility trying out? bye Nico |
January 17, 2006, 03:38 |
sorry, i mean relaxation facto
#32 |
Nico Petry
Rep Power: 17 |
sorry, i mean relaxation factor
January 17, 2006, 15:02 |
The default values are 0.3 on
#33 |
Muzio Grilli
Rep Power: 17 |
The default values are 0.3 on p an 0.7 on all the other variables. First you should tell me which is the shape of the G tensor you defined and which are the values you inserted.
Anyway try starting with 0.1 on p and 0.5 on the others. Then you should also look at the relative tolerances, try starting with 0.01 on p and 0.1 on the others then after a certain number of iteration switch to zero on all the variables |
January 17, 2006, 16:11 |
Hi Muzio:
[30000 0 0
G=
#34 |
Nico Petry
Rep Power: 17 |
Hi Muzio:
[30000 0 0 G= 0 15000 0 0 0 30000] Why shall I switch the relativ tolerances to zero. I don't understand the sence of it. Thanks for taking time for my problems. Nico |
February 6, 2006, 15:43 |
Hi, friends,
Could you plea
#35 |
Guoxiang
Rep Power: 17 |
Hi, friends,
Could you please sand the creatG.h and creatNu.h to me to learn? Thank you very much. email: gliu@mix.wvu.edu |
February 14, 2006, 11:37 |
Hello Muzio or someone else,
#36 |
Guido Adriaensen
Rep Power: 17 |
Sorry to ask for the same files as well. :-) But could you be so kind to share the created.H, createG.H, createNu.H -files? Thanks. If you can email it to guido.adriaensen@modesi.nl, I would be very gratefull, thanks again Guido |
March 6, 2006, 06:11 |
Dear OpenFoamers,
has anyon
#37 |
Dear OpenFoamers,
has anyone of you tried to simulate the unconfined seepage problem? The governing equation is grad(p)=-rho*nu*U/[K] + rho * [g] where [K] is the hydraulic conductivity (variable tensor) and [g] the gravity acceleration vector. Things are complicated by the fact that the phreatic level is not a-priori known, but is part of the solution (equilibrium condition at atmospheric pressure). For example, the goundflow in the picture below How the problem can be addressed? Is the customisation of interFoam the unique possibility? Thanks Michele. |
non-isotropic porous material | gmmh | FLUENT | 0 | September 4, 2007 07:38 |
Error while setting up porous material. | Kiddo | CFX | 1 | October 10, 2005 11:42 |
porous material | ioana | CFX | 2 | March 10, 2005 08:52 |
model for porous material | sleepinglily | CFX | 3 | October 19, 2004 11:45 |
Material in Porous media | Rajab Rajab | FLUENT | 3 | July 4, 2003 14:42 |
