Writing parallel code
Old   August 9, 2005, 13:41
Default Hi, I've written my own me
Markus Hartinger
hartinger is on a distinguished road
I've written my own mesh deformation routine and want to run it in parallel, but doesn't work yet. I have no experience in that either. Could you give me a hint, where to start. And probably list some DOs and DONTs.
Thank you
Markus
hartinger is offline   Reply With Quote
Old   August 9, 2005, 15:07
Default Since you only are moving poin
Mattijs Janssens
mattijs is on a distinguished road
Since you only are moving points (and not changing topology) you only have to make sure the point positions on processor patches are synchronized.
This is all done for you already in the motionSolver (see e.g. icoFoamAutoMotion.C) which determines internal point positions given boundary conditions.
If you want to do it yourself:
a. there are points on the processor patches shared between two processors only.
b. there are points shared between more than two processors.
a. is handled by sending one half to the other half and averaging so that both halves have the same value
b. is usually handled by sending all these coordinates to the master which determines a single value for all and sends it back.
Use motionSolver is my advice ;-)
mattijs is offline   Reply With Quote
Old   August 9, 2005, 15:20
Default thanks, i have a look on motio
Markus Hartinger
thanks, i have a look on motionSolver
markus
Old   March 11, 2006, 08:30
Default Dear all is it possible to ru
saeid kheradmand
skherad is on a distinguished road
Dear all
is it possible to run engine cases(geometry deformation ) in parallel?
thank you for your time
skherad is offline   Reply With Quote
Old   March 13, 2006, 14:07
Default The geometry deformation runs
Mattijs Janssens
The geometry deformation runs in parallel. There are some parallellizations problems though with other aspects of engine cases (notably injector specification). Have a search to find that one.
Programmerfriendly code writing how do you do that kar OpenFOAM Running, Solving & CFD 5 January 25, 2008 12:33
Writing a CFD code Ernesto FLUENT 2 March 27, 2007 18:38
writing a batch for a parallel run M CFX 4 December 15, 2005 01:09
writing a cfd code kelvin Main CFD Forum 13 October 13, 2005 06:41
Code writing Frank Scheuerpflug Main CFD Forum 15 May 19, 2005 07:02
