DecomposeParDict
Old   March 20, 2006, 17:18
Default Hi, I have a workstation wi
Pei-Ying Hsieh
hsieh is on a distinguished road
I have a workstation with 2 CPUs. I ran the decomposePar utility to decompose the case into two. In the original time=0 directory, gamma field has been initialized to have non-uniform distribution.
After running the decomposePar utility, I got processor0 and processor1. However, the gamma field on processor0/0 directory does not have non-uniform gamma field. Can someone suggest a solution? Thanks!
pei
hsieh is offline   Reply With Quote
Old   March 20, 2006, 18:05
Default Have you checked how the domai
Assistant Moderator
Bernhard Gschaider
Have you checked how the domain has been decomposed? Maybe in processor0's part the gamma-field IS uniform. For instance in the famous damBreak case this would be the case if processor0 gets the right part.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   March 21, 2006, 11:15
Default Hi, Bernhard, Thanks for th
Pei-Ying Hsieh
Hi, Bernhard,
Thanks for the reply. You are 100% correct. I found a problem (sort of). I compiled a modified version of rasInterFoam, called rasInterFoamInlet. I have no problem running the serial version of rasInterFoamInlet, however, when I ran rasInterFoamInlet in parallel, I got the following error:
phsieh@sun:~/OpenFOAM/phsieh-1.2/run/tutorials/rasInterFoam> mpirun -np 2 rasInterFoamInlet . CP-probeB -parallel
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.2 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : rasInterFoamInlet . CP-probeB -parallel
[1] Date : Mar 21 2006
[0] Date : Mar 21 2006
[0] Time : 09:30:22
[0] Host : sun
[0] PID : 8997
[1] Time : 09:30:22
[1] Host : sun
[1] PID : 8998
[1] Root : /home/phsieh/OpenFOAM/phsieh-1.2/run/tutorials/rasInterFoam
[0] Root : /home/phsieh/OpenFOAM/phsieh-1.2/run/tutorials/rasInterFoam
[0] Case : CP-probeB
[0] Nprocs : 2
[0] Slaves :
[0] 1
[0] (
[0] sun.8998
[0] )
[0]
Create time
[1] Case : CP-probeB
[1] Nprocs : 2
Create mesh, no clear-out for time = 0
Reading environmentalProperties
Reading field pd
Reading field gamma
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Calculating field g.h
Selecting turbulence model kEpsilon
Mean and max Courant Numbers = 0 0.02968
ICCG: Solving for pcorr, Initial residual = 1, Final residual = 9.92634e-11, No Iterations 205
time step continuity errors : sum local = 6.33051e-16, global = -6.8148e-17, cumulative = -6.8148e-17
Starting time loop
Mean and max Courant Numbers = 0.000532038 0.845396
deltaT = 1.5873e-06
Time = 1.5873e-06
One of the processes started by mpirun has exited with a nonzero exit
code. This typically indicates that the process finished in error.
If your process did not finish in error, be sure to include a "return
0" or "exit(0)" in your C code before exiting the application.
PID 8997 failed on node n0 (192.168.0.10) due to signal 11.
The following is the section I added to the original rasInterFoam:
// Get index of patch
label inletPatchID = mesh.boundaryMesh().findPatchID("inlet");
// Get reference to boundary value
vectorField& inletU = U.boundaryField()[inletPatchID];
// Manipulate value
velInlet = Foam::sin(3.14159/0.3158 * runTime.value());
velInlet = -150.0/0.3158/160.0 * velInlet;
if(runTime.value() >= 0.3158) velInlet=0.0;
inletU = vector(velInlet,0,0);
Info<< "inletU:" << min(inletU) << endl;
I have no problem running the original rasInterFoam in parallel.
Any suggestion will be highly appreciated.
Pei
Metis decomposeParDict problem certain patches on one processor diana OpenFOAM Running, Solving & CFD 3 September 9, 2009 06:33
Sensitivity to decomposeParDict variables metis egp OpenFOAM Running, Solving & CFD 10 July 9, 2009 03:41
