Read error
Old   August 5, 2005, 15:17
Default Dear all When it comes the ti
diablo80@web.de
sampaio is on a distinguished road
Dear all
When it comes the time to write data, my simulation crashes, issueing the following output (using a SGE queue system):
n-1<4053> ssi:boot:base:linear: booting n55 (tpol59)
n-1<4053> ssi:boot:base:linear: booting n56 (tpol61)
n-1<4053> ssi:boot:base:linear: booting n57 (tpol62)
n-1<4053> ssi:boot:base:linear: finished
--> FOAM FATAL ERROR : NO_READ specified for read-constructor of object U_0 of class IOobject
Function: regIOobject::readStream(const word&)
in file: db/regIOobject/regIOobjectRead.C at line: 53.
FOAM parallel run aborting
One of the processes started by mpirun has exited with a nonzero exit
code. This typically indicates that the process finished in error.
If your process did not finish in error, be sure to include a "return
0" or "exit(0)" in your C code before exiting the application.
PID 23695 failed on node n0 (10.1.1.64) with exit status 1.
[anieckele@lcad10 oodles]$
It seems to be a read problem (NO_READ on U_0), but it happens at the exact instant of writing the fields. p, k, etc.. are writen, but when it comes to U_0, it crashes...
Do you have any clue?
sampaio is offline   Reply With Quote
Old   August 8, 2005, 07:37
Default Have a search on the site for
Mattijs Janssens
mattijs is on a distinguished road
Have a search on the site for NO_READ or nfs. This problem has been discussed before quite a few times.
mattijs is offline   Reply With Quote
Old   August 8, 2005, 09:56
Default Hi, am trying to incomperat
Kanyanta Valentine
valentine is on a distinguished road
am trying to incomperate stress analysis in the icoFoam solver but after copying the solver into my user application bin and modifying, its giving me this error "getApplicationClass::Invalid application class name" followed by the name of my application. Can somebody please help
valentine is offline   Reply With Quote
Old   August 8, 2005, 09:58
Default Hi, am trying to inco-opera
Kanyanta Valentine
am trying to inco-operate stress analysis in the icoFoam solver but after copying the solver into my user application bin and modifying, its giving me this error "getApplicationClass::Invalid application class name" followed by the name of my application. Can somebody please help
Old   August 8, 2005, 15:15
Default This message is from FoamX?
Mattijs Janssens
The application class is whatever is in system/controlDict in the 'application' setting.
If you have created a new solver and want to use it from FoamX you will also need to create the corresponding configuration files (try to find e.g. icoFoam.cfg and have a look at that)
Old   August 10, 2005, 11:07
Default Thanks Mattijs, I found the p
diablo80@web.de
Thanks Mattijs,
I found the posts about the NO_READ problems, and now OpenFOAM is able to write the time directories.
The only thing is that now if I change writeInterval in controlDict (after stopping the simulation), it doesnot use the new values in the next run...
I also observed that it actually updates to the new values on the next days or two... which is weird.
I checked the date on the machines and the time on the files and seems normal.
Is there anything else I can check?
Is this weird behaviour caused by a change in fileModificationSkew? (I changed it to 1000000 and later to 100)
Thanks a lot
Old   August 10, 2005, 19:06
Default Check your nfs update interval
Mattijs Janssens
Check your nfs update interval. This is usually a few seconds. Just e.g. 'touch' a file and see when it appears on the other machines.
Old   March 30, 2006, 14:35
Default Just saw this one: For peop
Mattijs Janssens
Just saw this one:
For people whose cluster is not time-synchronized: check out NFStimesync.
http://nfstimesync.sourceforge.net/
It runs in user space and makes all computers appear to run the same time.
Old   April 19, 2006, 09:44
Default Cac someone help me please. I
Kanyanta Valentine
Cac someone help me please. I have this problem when running Stressed Foam. The only changes I have made is on E and nu, which are now time dependant. the problem seems to be with exp(t/T) function but don't know how to clear it.
dimensionedScalar rho(mechanicalProperties.lookup("rho"));
dimensionedScalar rhoE(mechanicalProperties.lookup("E0"));
dimensionedScalar t = runTime++;
Info<< "Normalising E : E/rho\n" << endl;
dimensionedScalar E = rhoE/rho*
1.0 - 0.015*(1.0 - exp(-(t/T1))) - 0.08*(1.0 - exp(-(t/T2))) - 0.0266*(1.0 - exp(-(t/T3)))
dimensionedScalar nu = ((74.01 - E)/148.02);
Info<< "Calculating Lame's coefficients\n" << endl;
dimensionedScalar mu = E/(2.0*(1.0 + nu));
dimensionedScalar lambda = nu*E/((1.0 + nu)*(1.0 - 2.0*nu));
dimensionedScalar threeK = E/(1.0 - 2.0*nu);
the constants T1, T2, T3 are declared as below
Info<< "Reading relaxation time constants\n" << endl;
IOdictionary relaxationTimeConstants
IOobject
"relaxationTimeConstants",
runTime.constant(),
runTime,
IOobject::MUST_READ,
IOobject::NO_WRITE
dimensionedScalar T1(relaxationTimeConstants.lookup("T1"));
dimensionedScalar T2(relaxationTimeConstants.lookup("T2"));
dimensionedScalar T3(relaxationTimeConstants.lookup("T3"));
but when I run the solver I get the following error
FOAM FATAL ERROR : ds not dimensionless
Function: exp(const dimensionedScalar& ds)
in file: dimensionedTypes/dimensionedScalar/dimensionedScalar.C at line 157.
FOAM aborting
I thought t = runTime++ is in seconds and hence T are dimensioned in seconds.
mpt read error 10054 zenith FLUENT 1 February 11, 2012 06:22
Fluent Read Error Joe FLUENT 4 September 23, 2008 22:16
Read/Write error Alec Eiffel FLUENT 6 June 8, 2005 02:53
RE: Fluent Read Error Chris FLUENT 13 April 16, 2005 19:56
Error: can't read face in model coriolius Siemens 1 October 21, 2004 09:47
