Office Room
Old   June 2, 2006, 14:45
Default Hi, at first my english is
myting
at first my english is not so good. I hope you can understand me :-)
Normaly I used Airpak (FLUENT) to simulate the airflow in rooms but now I found the OpenFOAM Software. So I will make a simple office in OpenFOAM and compare the solution with Airpak.
Can somebody help me to adjusting OpenFOAM. So I can use the solver for other similar problem in closed room with air?
Describe the Office room:
The Office room has three slot supply air outlet and three slot exhaust air outlet. The supply temperature is 16°C with 4.016 m/s (turbulence). The indoor air temperature is 24°C. The room dimensions are about 4.3 m, 4.13, 3.17 m. The wall temperature are 24°C.
The Model Data:
Maybe this picture show a little bit more about my room.
I want use the k-e-Model.
I tried to solve the problem but it was impossible for me :-(
Thank you for your help
Myting
Old   June 3, 2006, 03:42
Default Hi, the model data: /*--
myting
the model data:
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.3 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
// FoamX Case Dictionary.
FoamFile
version 2.0;
format ascii;
root "/home/myting/OpenFOAM/myting-1.3/run/OfficeKlima";
case "Office";
instance "constant/polyMesh";
local "";
class dictionary;
object blockMeshDict;
arguments "/home/myting/OpenFOAM/myting-1.3/run/OfficeKlima/Office" off;
convertToMeters 1;
vertices
(0 0 0)
(4.32 0 0)
(4.32 3.17 0)
(0 3.17 0)
(0 0 4.13)
(4.32 0 4.13)
(4.32 3.17 4.13)
(0 3.17 4.13)
(0.3695 2.745 0)
(0.7845 2.745 0)
(0.7845 2.755 0)
(0.3695 2.755 0)
(0.3695 2.745 0.001)
(0.7845 2.745 0.001)
(0.7845 2.755 0.001)
(0.3695 2.755 0.001)
(1.0235 2.745 0)
(1.4385 2.745 0)
(1.4385 2.755 0)
(1.0235 2.755 0)
(1.0235 2.745 0.001)
(1.4385 2.745 0.001)
(1.4385 2.755 0.001)
(1.0235 2.755 0.001)
(1.6775 2.745 0)
(2.0925 2.745 0)
(2.0925 2.755 0)
(1.6775 2.755 0)
(1.6775 2.745 0.001)
(2.0925 2.745 0.001)
(2.0925 2.755 0.001)
(1.6775 2.755 0.001)
(2.3315 2.745 0)
(2.7465 2.745 0)
(2.7465 2.755 0)
(2.3315 2.755 0)
(2.3315 2.745 0.001)
(2.7465 2.745 0.001)
(2.7465 2.755 0.001)
(2.3315 2.755 0.001)
(2.9855 2.745 0)
(3.4005 2.745 0)
(3.4005 2.755 0)
(2.9855 2.755 0)
(2.9855 2.745 0.001)
(3.4005 2.745 0.001)
(3.4005 2.755 0.001)
(2.9855 2.755 0.001)
(3.6395 2.745 0)
(4.0545 2.745 0)
(4.0545 2.755 0)
(3.6395 2.755 0)
(3.6395 2.745 0.001)
(4.0545 2.745 0.001)
(4.0545 2.755 0.001)
(3.6395 2.755 0.001)
blocks
hex (0 1 2 3 4 5 6 7) (40 40 40) simpleGrading (1 1 1)
hex (8 9 10 11 12 13 14 15) (2 2 2) simpleGrading (1 1 1)
hex (16 17 18 19 20 21 22 23) (2 2 2) simpleGrading (1 1 1)
hex (24 25 26 27 28 29 30 31) (2 2 2) simpleGrading (1 1 1)
hex (32 33 34 35 36 37 38 39) (2 2 2) simpleGrading (1 1 1)
hex (40 41 42 43 44 45 46 47) (2 2 2) simpleGrading (1 1 1)
hex (48 49 50 51 52 53 54 55) (2 2 2) simpleGrading (1 1 1)
edges
patches
wall kuehldecke
(3 7 6 2)
wall waende
(0 3 2 1)
(2 6 5 1)
(6 7 4 5)
(7 3 0 4)
(0 1 5 4)
patch AB1
(11 10 9 8)
patch ZU1
(19 18 17 16)
patch AB2
(27 26 25 24)
patch ZU2
(35 34 33 32)
patch AB3
(43 42 41 40)
patch ZU3
(51 50 49 48)
mergePatchPairs
Old   June 6, 2006, 16:02
Default Hi Thomas i had a look on y
atzaru
Hi Thomas
i had a look on your geometry but it is not very clear to me. Can you change it and give suggestive names for inlet outlet groups (instead of AB1 AB2 ... )? You can have a look on what you have done in Paraview without any iteration before.
Normally to calculate this you should use BuoyantSimpleFoam solver
atzaru
Old   June 12, 2006, 09:41
Default Thanks for your answer. I will
myting
Thanks for your answer. I will change my geometry and make it clear in next few days. I will show it here after I finish the work.
Modelling of temperature in office environment Lincoln Chua Main CFD Forum 3 April 3, 2008 11:44
HAVC and office comfort simulatio info@interirordesin.com Main CFD Forum 0 March 28, 2004 12:49
Dat file in Office David FLUENT 1 November 14, 2003 14:44
Fluent office in Toronto? Ray FLUENT 1 June 5, 2000 22:38
