January 24, 2006, 13:40 |
Hi everybody,
I am a beginn
Magnus Åberg
Rep Power: 17 |
Hi everybody,
I am a beginner OpenFOAM user with a wish of doing an investigation of the acoustics generated by a transonic jet through a nozzle. For this I tried rhoSonicFoam with initial conditions for the velocity field given by an incompressible solution of the same case. I then start the compressible case using a really low Courant number. After some 6000 iterations the calculation still looks good but then blows up very quickly. This is the case both when i use higher order vanLeer but also when I tried the upwind scheme. As I am a beginner user maybe this is not the right solver that I have choosen. Does anybody have ideas/suggestions of what I can do? Thanks for your kind answers! /Magnus |
January 25, 2006, 03:20 |
It is usually something physic
Mattijs Janssens
Rep Power: 26 |
It is usually something physical happening that causes this blowing up after such a long time of stable running. Check the solution just before it blows up. Maybe there is something happening (inflow?) at the outlet? Is the initial shock (from starting from an incompatible solution) reaching the outlet. Or is the solution finally going supersonic?
January 25, 2006, 03:38 |
IC and BC should always be an
Shiuh-Hwa Shyu (Steven)
Rep Power: 17 |
IC and BC should always be an issue. A bad IC might eventially kills your calculation. But sometimes, the code might get survived and give you final solution. This would depend on the physical problem. As for BC, it would either give you a wrong solution, or just blow up. In my experience, the FDM tends to survive for quite a long period of time before it blows up, or gives you wrong solution. As for the spectral-like method, it would diverge quite quickly. This is a good thing though.
January 25, 2006, 10:17 |
Many Thanks for your input!
Magnus Åberg
Rep Power: 17 |
I restarted my calculations, using first order schemes, with zero for pressure and velocity in the interior. I can see that the problem comes from the inlet patch I looked throught my boundary conditions and I found that maybe I misunderstand the meaning of pressureInletVelocity. What is the value i need to specify there? I want to specify totalpressure and totaltemperature what is the correct velocity BC for this setup? /Magnus |
January 25, 2006, 10:19 |
Magnus Åberg
Rep Power: 17 |
February 1, 2006, 11:54 |
I realize that what i w
Magnus Åberg
Rep Power: 17 |
I realize that what i wanted to do is not implemented. So I ask instead if somebody can give me a suggestion of which solver to use for a transonic turbulent jet with moving shocks. The inlet is subsonic and I whish to use LES for closure. Thank you /Magnus |
February 1, 2006, 12:23 |
coodles with
"transonic true
Eugene de Villiers
Rep Power: 21 |
coodles with
"transonic true;" added to the PISO subdictionary. No way it will capture shocks properly though. |
February 11, 2006, 14:57 |
Could I modify sonicFoam (merg
Thomas Hauser
Could I modify sonicFoam (merge with coodles) to create a LES solver for compressible flow with shocks? Or are there better ways?
June 14, 2006, 02:43 |
I have the same question as wh
#9 |
Dihao Tang
Rep Power: 17 |
I have the same question as what Magnus asked:
"I want to specify totalpressure and totaltemperature what is the correct velocity BC for this setup?" I also use coodles, hope somebody can give me the answer, thanks! |
AVL Fire transonic simulation | Ainil | Main CFD Forum | 1 | August 24, 2010 15:53 |
transonic simulation with OpenFoam | Shyam | Main CFD Forum | 0 | June 12, 2008 02:39 |
Simulation of transonic flow over NACA0012 airfoil | MSc Student | Siemens | 2 | August 9, 2006 13:49 |
Compressible transonic airfoil RAE2822 simulation | Stefano | Siemens | 9 | June 21, 2006 10:47 |
Transonic DNS | cfd-freak | Main CFD Forum | 1 | April 16, 2003 12:39 |
