About the usage of polyDualMesh
Old   April 14, 2006, 07:43
Default In release notes for 1.3, i
Wei Jing
weijing is on a distinguished road
it talked about there are several newpost-processing utilities added--including
"polyDualMesh"
(converts polyMesh into its vertex-based dual mesh)"
I try to know how to use this,but there are no information about its usage.
Do someone know how to use,or have a example case about that?
thank you very much!
weijing is offline   Reply With Quote
Old   April 18, 2006, 07:19
Default Take a mesh (e.g. lid-driven c
Mattijs Janssens
mattijs is on a distinguished road
Take a mesh (e.g. lid-driven cavity tutorial) and run polyDualMesh. It will write a new mesh in a time directory (0.0005?). Move this polyMesh directory to the constant directory.
It will run on any OpenFOAM mesh. Quite funny on tet meshes.
mattijs is offline   Reply With Quote
Old   April 19, 2006, 00:31
Default thank you!http://www.cfd-onlin
Wei Jing
thank you!
And the name of this time directory is decided by "deltaT" in controlDict.
If we set deltaT=100,it will write new mesh to (case)/100/polymesh .
Old   June 15, 2006, 08:54
Default Is there other command to run
Wei Jing
Is there other command to run analysis for "node based" mesh?
now I have a dual mesh,but the results looks not having difference with orignal mesh.
Problems on Tetrahedra to Polyhedra using polyDualMesh on concave surface object chnrdu OpenFOAM Pre-Processing 2 July 18, 2009 13:58
PolyDualMesh crash caused by functions in contralDict zeliboba OpenFOAM Bugs 1 September 28, 2008 12:06
50% CPU usage AEsco48 CFX 9 March 13, 2008 17:44
usage of UDS & UDM Tong FLUENT 2 February 15, 2006 11:32
CFX-5.7.1 RAM usage Sandeep CFX 1 January 30, 2005 18:14
