Calculation of bounded scalars
Old   June 19, 2006, 02:59
Default Hi, I am solving for a turb
Ankur Gupta
ankgupta8um is on a distinguished road
I am solving for a turbulent mixing (using LES model) of a passive scalar in a turbulent flow. The scalar has lower and upper bounds of 0 and 1 (as contrained by the boundary conditions). However, when solved, I get values in the computational domain which are like -0.001 and 1.001.
What steps need to be taken in terms of solver settings (or anything else that would help) so as to aviod getting the scalar values out of the bounds ??
Thanks in advance.
Regards,
Ankur
ankgupta8um is offline   Reply With Quote
Old   June 19, 2006, 06:03
Default You need to use a bounded diff
Eugene de Villiers
eugene is on a distinguished road
You need to use a bounded differencing scheme for the scalar. E.g.
div(phi,gamma) Gauss limitedLinear01 1;
eugene is offline   Reply With Quote
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 09:30
Bounded scheme gives unbounded solution su_junwei OpenFOAM Running, Solving & CFD 3 November 18, 2011 03:35
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 21:21
Bounded slice in Tecplot possible? Sam Tecplot 1 August 20, 2008 13:18
if two scalars calculation in scalfn.f mspark Siemens 2 April 5, 2004 03:49
