Mass sink and mass source in eulerTwoPhase application |
April 19, 2006, 03:08 |
Hi!
Im trying to do a simul
Hi!
Im trying to do a simulation where water is heated to vapor. To do This im planing on using the eulerTwoPhase application with added heat equations. But since the water becomes vapor att the patches difined as heat sources, I need to take away water in the outer most cells i.e. mass sinks and create vapor in the same cells i.e. mass sources. Does anyone know how to create such sources/sinks Thanks /Erik |
April 28, 2006, 20:24 |
Hello erik:
Treat the mass
Rep Power: 17 |
Hello erik:
Treat the mass and sink sources as momentum sources and add/subtract their values from the momentum equations. Its a pseudo approach but kinda throws light on the physics Vatant |
May 3, 2006, 07:42 |
Thanks a lot!
I would like
Thanks a lot!
I would like to make this phase shift at one of the walls. Do you also know how to edit this so that it looks like vapor is created at the walls and not with a even distribution on the cross section area? i.e. I probably have make these equations on the cells closest to the wall. best regards /Erik Arlemark |
July 9, 2006, 08:15 |
Hello again,
I got a bit di
Hello again,
I got a bit disoriented when trying to make out the code for twoPhaseEulerFoam. Could you or perhaps someone else help me find the momentum equation (is it the one in Ueqns.H?) and maybe point out where to add resp. subract with mass sources in order to simulate creation of vapor. |
HELP! adding a mass source to VOF eqn. by UDF??? | ROOZBEH | FLUENT | 5 | December 3, 2016 18:53 |
mass source and mass sink for multi-component | frank | CFX | 0 | May 14, 2008 12:55 |
help on mass sink using CEL function | buhkuh | CFX | 0 | March 19, 2008 00:57 |
mass sink UDF | H | FLUENT | 1 | November 8, 2004 23:44 |
help on UDF mass source | shao1 | FLUENT | 2 | July 11, 2002 21:36 |
