Correct turbmodel for airflow with Re 55000
Old   July 22, 2006, 04:56
Default Hello! Im trying to model a
newbee
Hello!
Im trying to model a an airflow in a channel with Re = 55000. Im not sure which turbmodel to use for this but most of the models that i have tried have ended up with results looking too laminar compared with experimental values. I might be calculating the k and epsilon BC/IC values wrongly.
The way i try to calculate them is:
k = 0,002*Ub*pow(2)
ļ„epsilon = k*pow(3/2)/(0,3*Dh)
where Ub is bulkvelocity and Dh is the hydralic diameter.
So far i have treated the flow as higher turbulent and used wallFunctions with zeroGradient on k.
Does anyone have a suggestion for me what to do to make my flow look more turbulent?
This image illustates my flow profile. the upper patch is a wall and the three others are symmetryplanes. According to the experemental data the magnetude of U should not be higher then 25.2 m/s.
Thanks
/Erik
Old   July 22, 2006, 05:30
Default I forgot to mention that I wan
newbee
I forgot to mention that I want a turbmodel for incompressible flow and the calculations are to be steady state.
Turbulant airflow behind 2D airfoil Adam CFX 8 January 24, 2008 20:14
How to model an airflow over a water? Luk CFX 3 January 10, 2008 04:39
Computer chassis airflow Justin CFX 5 May 2, 2007 19:17
Airflow deflector..please help Riham FLUENT 0 October 16, 2003 19:34
2D Airflow Analysis Scott Stammer Main CFD Forum 1 April 13, 2002 09:43
