July 25, 2006, 09:14 |
If I want to write the Cp ever
Dihao Tang
Rep Power: 17 |
If I want to write the Cp every writeInterval, how do I change the code below:
template<class> tmp<volscalarfield> hThermo<mixturetype>::Cp() const { const fvMesh& mesh = T_.mesh(); tmp<volscalarfield> tCp ( new volScalarField ( IOobject ( "Cp", mesh.time().timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), mesh, dimensionSet(0, 2, -2, -1, 0) ) ); The obove was extracted from hThermo.C which I think is responsible for writing the value into the Cp file after a writeInterval. So by referencing other variable like p or T. I changed IOobject::NO_WRITE into IOobject::AUTO_WRITE. But still not saw Cp. How do I change the code correctly? Thank you so much! |
July 25, 2006, 10:48 |
By the way, I clarify my quest
Dihao Tang
Rep Power: 17 |
By the way, I clarify my question. I'm using sonicTurbFoam and I set the thermoType as
hThermo<puremixture<sutherlandtransport<speciether mo<janafthermo<perfectgas>>>>> ; The current situation is that after running a case, I intend to use postprocessing method like calcMassFlow or something like that to output the Cp value as well as h. My idea is that to read the Cp value from for example "0.003" directory. But the prerequisite must be that I write the Cp data into a file called Cp the same as p, T, U and so on. I also took a look at the basicThermo.C and .H, but I cannot move forward now, can someone give me a hand? Thanks! |
Help me please..Write udf define_CG_motion | Apple | FLUENT | 1 | July 21, 2009 07:31 |
Write at last iteration | diegon | OpenFOAM Running, Solving & CFD | 2 | December 5, 2006 06:03 |
Write .cas and .dat for Unsteady | TK | FLUENT | 2 | September 12, 2005 06:53 |
UDF TO WRITE OUT DATA!! | Aishwarya | FLUENT | 0 | August 12, 2004 11:11 |
How to write CCL 2 computers | Kemi | CFX | 1 | May 3, 2004 19:09 |
