August 23, 2006, 13:47 |
Thanks in advance .
i
Manuel Felipe Mejia De Alba
Rep Power: 17 |
Thanks in advance . i try to run a nozzle model, very simple, using icofoam. After try and try, and try ;-), run without problems. I run the same model in ANSYS and the result are not equal. In ansys, i need the density, but in IcoFoam No. what equations solved icofoam, where not is necesary the density.?? My model is a modifid cavity, whit the nu 0.01. thanks. ________________ Hola Gracias por adelantado. yo estoy tratando de correr un modelo de una tobera sencilla. Despues de tratat y tratar, logre que corriera sin problemas. Yo tratto de correr el mismo ejemplo en Ansys, pero el resultado no es el mismo. Ademas en ansys es necesario la densidad pero en icofoam no. Que ecuaciones resuelve icofoam, donde no es necesario la densidad? Mi modelo es como el modelo cavity pero modificado, con nu de 0.01 Gracias Manuel F. Mejia De Alba Universidad Nacional de Colombia. |
August 23, 2006, 14:41 |
In icoFoam, the pressure being
Gavin Tabor
Rep Power: 17 |
In icoFoam, the pressure being solved is not the true pressure but is in fact p/rho. Thus the density cancels out throughout.
Gavin |
August 24, 2006, 17:50 |
Hi
Ok, the press is equal.
Rep Power: 17 |
Hi
Ok, the press is equal. But, what happend whit the velocity, the graphics change, when change the density. how i do, for make a model with the density of any value. thanks |
August 24, 2006, 18:00 |
Multiply the pressure field wi
Hrvoje Jasak
Rep Power: 33 |
Multiply the pressure field with the value of density. If you want to feel really good about it, you can also add it an offset, e.g. 101325 Pascal for air at atmospheric conditions.
This can all be done after the simulation and there's no need to change the solver. Look at the magU utility for examples - you will be manipulating the pressure instead. Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
August 24, 2006, 18:37 |
ok, with the press, i not have
Rep Power: 17 |
ok, with the press, i not have problems
my doubts are with the velocity field: this is independent of density?? thanks and sorry the insistence. Manuel. |
August 25, 2006, 08:26 |
Velocity is fine: remember, yo
Hrvoje Jasak
Rep Power: 33 |
Velocity is fine: remember, you only have grad p in the momentum equation and that does not change for arbitrary offset of p.
Enjoy, Hrv
August 26, 2006, 13:35 |
Hi again, and I am sorry for i
Rep Power: 17 |
Hi again, and I am sorry for inconvenients for so many questions. One more, when I`m looking in the icofoam solver code, it appears a phi term (like a field Phi), that is multiply for velocity, and I`m not sure if that term is related with viscous loss term of generalized momentum equation. The problem is that changes in the kinematic viscosity produces big changes in the velocity field pattern, and not only in velocity field values.
Thanks again |
August 26, 2006, 13:42 |
Rep Power: 17 |
September 22, 2010, 05:10 |
#9 |
Pavan
Rep Power: 17 |
Yeah but when you change viscosity you're changing Reynolds number so you should expect a change in flow field. Also if I'm not mistaken, Phi is a scaled flux per unit density per unit area...?
IcoFoam | aap | OpenFOAM Running, Solving & CFD | 15 | May 28, 2012 09:30 |
About phi in icoFoam | kar | OpenFOAM Running, Solving & CFD | 3 | February 20, 2008 06:20 |
Possible bug in icoFoam | msrinath80 | OpenFOAM Bugs | 6 | November 19, 2007 18:35 |
Need help for a simple example with icoFOAM | gruber2 | OpenFOAM Running, Solving & CFD | 3 | April 3, 2007 07:26 |
IcoFoam on AIX 53 | ds2taieb | OpenFOAM Installation | 1 | March 24, 2006 04:22 |
