Boundary Condition
Old   April 15, 2005, 11:59
Default Hello, I tried to use "pres
vatant is on a distinguished road
I tried to use "pressureTransmissive" boundary condition with lInf specified. however, when i ran my code : it said ,
FOAM FATAL IO ERROR : keyword lInf is undefined in dictionary "/run/tutorials/../0/p:: Outlet"
Function:dictionary :: lookupEntry (const word& keyword) const
in file : db/dicitonary/dictionary.C at line : 148
I dont know how to fix this. Should i include any extra lib files in /make/options ?
Thanks
Vatant
vatant is offline   Reply With Quote
Old   April 15, 2005, 12:14
Default It sounds like you have made a
henry is on a distinguished road
It sounds like you have made a mistake in way you have added the lInf entry.
henry is offline   Reply With Quote
Old   April 15, 2005, 12:39
Default In the /case/0/p file bound
boundaryField
Outlet
type pressureTransmissive;
pInf 1e5;
lInf 0.5;
etc
I did not use pressureTransmissive type patch in the mesh i imported frm fluent.
Do you think, I need to add the pressure type patch anywhere else ?
Thanks
Vatant
Old   April 15, 2005, 15:52
Default Dr.Weller, I tried to u
Dr.Weller,
I tried to use zeroGradient for velocity at outlet and this error disappeared. However, I have an compressible flow scenario and hence my rho field reads:
Inlet
type inletOutlet;
inletValue 920;
Outlet
type inletOutlet;
inletValue 900;
I tried using this condition using OpenFoam 1.0 and Foam Exited.
I am not sure how to handle the pressuretransmissive nature using Foam...
in my case, i have an totalpressure in a tank with an exit nozzle where pressuretransmissive is required due to reflective boundary nature.
( a compressible laminar liquid flow)
My velocity at inlet is 'pressureinletoutletvelocity' calculated using the total pressure ..and at outlet ..i guess..zerogradient is appropriate due to pressuretransmissive nature.
the domain is initially with water everywhere..and hence i used,
inlet
type inletOutlet;
inletValue ...
and at the Outlet..i tried different combinations
I had earlier run with constant pressure outlet (fixed value) but the solution easily showed boundary reflection.
Could you help me handle the boundary conditions ?
Thanks
Vatant
Old   April 15, 2005, 18:38
Default The pressureTransmissive press
The pressureTransmissive pressure BC is currently written for gases not liquids, if you need a version for liquids you will have to write a version for yourself based on the one I wrote for gases.
Old   April 15, 2005, 19:20
Default Thanks Dr.Weller. Where can i
Thanks Dr.Weller. Where can i find pressureTransmissive BC module for gases so that I can try and set one up for liquids.
Vatant
Old   April 17, 2005, 08:20
Default You will find the source code
You will find the source code for all the physical boundary conditions in OpenFOAM-1.1/src/OpenFOAM/fields/fvPatchFields/derivedFvPatchFields
Old   April 18, 2005, 10:30
Default How can i include the required
How can i include the required boundary conditions patch fields to my /username/applications ?
I have the required p0, rho0,psi for calculation in pressureTransmissive ..does it require any other parameter ? I guess the p0 is the boundary outlet pressure itself ..with rho0 = rho(t=0) given.
With these where should i place my fields file *.C and *.H for my application ?
Thanks
VATANT
Old   April 19, 2005, 20:06
Default Dr.Weller, I modified onl
Dr.Weller,
I modified only the p0, rho0 and PSI for pressureTransmissive to read. Does this condition work differently for gas and liquids or can i jus use different p0, rho0 and PSI (for liquids) ?
In the pressureTransmissive conditions, wht if lInf = 0 does it imply completely non-reflective conditions ( I guess this is Navier Stokes Characteristic Boundary Condition NSCBC's)
Also, If my actual boundary value (pressure exit ) is say Pexit, does Pinf in pressureTransmissive same as Pexit ? (if it was a fixedValue pressureOutlet) ?
Thanks
Vatant
Old   September 19, 2005, 16:58
Default I patch a value of a field in
olivier Petit
olivier is on a distinguished road
I patch a value of a field in a wall boundary at each iteration.
what is the type which I should associate to this boundary, knowing that zeroGradient generate a false segmentation after the 4th iteration.
thanks a lot
olivier is offline   Reply With Quote
Old   September 20, 2005, 13:49
Default can some one help me please th
  #11
olivier Petit
can some one help me please thank you
Old   September 20, 2005, 14:10
Default I dont understand what you mea
  #12
Eugene de Villiers
eugene is on a distinguished road
I dont understand what you mean. If you are altering the boundary value, it clearly cant be zeroGradient. What are you doing and why are you doing it?
eugene is offline   Reply With Quote
Old   September 20, 2005, 18:36
Default Hi Eugene I have two zones of
  #13
olivier Petit
Hi Eugene
I have two zones of calculation, over these zones I resolve different equations.
potential vector values obtained in the inferior wall (buttom) of the 1st zone must be patched in the walls superior wall (top) of the 2nd zone.
what is the type which I should associate to this boundary (superior and inferior wall).
thanks a lot
Old   September 21, 2005, 05:06
Default I guess something like bott
  #14
Mattijs Janssens
mattijs is on a distinguished road
bottom: zerogradient (i.e. extrapolated from the internal values)or better inletOutlet.
top: fixedValue
mattijs is offline   Reply With Quote
Old   August 28, 2006, 11:48
Default Hello, Could someone give m
  #15
Jeff Allen
jballen is on a distinguished road
Could someone give me an example of using the findNearestBoundaryFace function, given a coordinate location.
Thanks,
Jeff
jballen is offline   Reply With Quote
Boundary condition for UDS Tomik FLUENT 0 December 5, 2006 18:37
Boundary condition of the third kind or Danckwertz boundary condition plage OpenFOAM Running, Solving & CFD 4 October 3, 2006 13:21
Slip Boundary Condition for Moving Boundary Shukla Main CFD Forum 3 November 11, 2005 16:02
UDF boundary condition Jeff FLUENT 2 November 20, 2003 18:15
Boundary Condition in LES Zhang Tsiang Main CFD Forum 3 February 5, 2002 21:15
