Missing output files
Old   August 31, 2006, 10:22
Default I am missing some output files
stefan
stefanke is on a distinguished road
I am missing some output files like epsilon and k in my time directories. Additional one of my species (the first) one is missing. All other output like p,U,T and all other species were sucessfully written into the time dir.
Does anyone has an idea or know how to track this strange behaviour?
stefanke is offline   Reply With Quote
Old   September 7, 2006, 04:44
Default Any ideas ?
stefan
Any ideas ?
Old   September 7, 2006, 04:51
Default Most propably you don't have t
Assistant Moderator
Bernhard Gschaider
Most propably you don't have turbulence enabled (or you're using a turbulence model that doesn't use k and epsilon). Which solver are you using?
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   September 7, 2006, 04:57
Default Turbulence is enabled and I us
stefan
Turbulence is enabled and I use the RNG k-epsilon turbulence model. The solver is a user-coded one but I am do not aware that there is something which is related to my problem.
Old   September 8, 2006, 05:51
Default Try playing around with thw wr
Assistant Moderator
Bernhard Gschaider
Try playing around with thw writeOpt()-Method (inherited from IOobject) of the k and eps fields. My guess is that this was set from AUTO_WRITE to NO_WRITE somewhere ....
output files size MAB FLOW-3D 1 October 24, 2008 22:54
about the output to CFX files Ben CFX 4 January 16, 2008 14:34
Writing additionnal output files during a run laurentgla OpenFOAM Running, Solving & CFD 3 May 25, 2007 11:35
Input and output files Vyatscheslav CFX 0 September 15, 2005 12:40
