September 15, 2006, 05:01 |
Hi. I want to run a 3D case wh
Pascal Müller
Rep Power: 17 |
Hi. I want to run a 3D case where a wheel is rotating in a cylinder with the symmetrie-axis of the cylinder. the cylinder is for about 20 percent filled with a liquid. in the wheel are some wholes, so that the rotating wheel schould lift up some parts of the liquid. I thought of taking the interFoam-case for the model and filling the cylinder with the setFields-command with the liquid (just like the damBreak). for the rotation I thought of using the staticFvMesh, because only the wheel is rotating. is this correct, or should I use the mixer for this problem? and how should I proceed further? I dont have much experience with all this stuff, so it would be nice if you could tell me what I am doing wrong or what I have to consider.
greetings, Pascal |
Rotating bike wheel | E. Turner | FLUENT | 3 | October 1, 2006 01:44 |
Advise with a wheel simulation | Freeman | FLUENT | 4 | November 22, 2005 11:00 |
Water wheel formula, please ? | Externet | Main CFD Forum | 0 | August 30, 2005 02:06 |
Flow field around wheel | Lorenzo Pavarin | FLUENT | 1 | July 3, 2000 11:41 |
Paddle Wheel | Ron | Main CFD Forum | 0 | December 17, 1998 00:54 |
