Problem with Parallel not with Serial
Old   September 18, 2006, 07:03
Default i am using coodles for LES sim
iyer_arvind
i am using coodles for LES simulation for a mixing layer. After several thousand iterations, (when i guess that the gradients are large over the partition boundary) the solver crashes due to temperature iterations not converging (typically due to unphysical temperatures). if i go back a few steps and start the process in serial mode the there is absolutely no problem, it does not cause any unphysical temperatures and the courant numbers are stable, as opposed to the former. Is there any problem in the parallel solver?
More DPM incompletes in parallel than in serial Paul FLUENT 0 December 16, 2008 10:27
Serial vs parallel different results luca OpenFOAM Bugs 2 December 3, 2008 11:12
Serial OK parallel failsmesh conversion problem r2d2 OpenFOAM Running, Solving & CFD 15 July 31, 2008 16:04
Serial run OK parallel one fails r2d2 OpenFOAM Running, Solving & CFD 2 November 16, 2005 13:44
parallel Vs. serial co2 FLUENT 1 December 31, 2003 03:19
