TwoDMotion appears in compilation
Old   September 30, 2006, 11:10
Default Hi; I get a problem when I tr
mer
merrouche djemai
mer is on a distinguished road
Hi;
I get a problem when I try to compile the solver freeSurface in surfaceTracking (openFoam-1.3_29_08_06) within OpenFoam-1.3. the compilation gives me the error:
FreeSurface.C:1390:error:'class Foam::tetDecompositionMotionSolver' has no member named 'twoDMotion'.
I search with doxygen and found the 2-D motion corrector pointer in the motion smoother class, but I can't eliminate the error.
Can any one here help me to resolve this problem.
mer is offline   Reply With Quote
Old   September 30, 2006, 11:27
Default Hi, In order to help you I
Hrvoje Jasak
In order to help you I need more info. For starters, I assume you are compiling my development version, right? Secondly, I cannot find the file called "FreeSurface.C" in the whole of OpenFOAM. Do:
foam
find . -name FreeSurface.C
and give me a result. There is a file called "freeSurface.C" and that compiles and runs without problems:
SOURCE=freeSurface.C ; g++ -m32 -Dlinux -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-30 -I/home/hjasak/OpenFOAM/OpenFOAM-1.3/src/finiteArea/lnInclude -I/home/hjasak/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude -I/home/hjasak/OpenFOAM/OpenFOAM-1.3/src/dynamicMesh/lnInclude -I/home/hjasak/OpenFOAM/OpenFOAM-1.3/src/tetDecompositionMotionSolver/lnInclude -I/home/hjasak/OpenFOAM/OpenFOAM-1.3/src/tetDecompositionFiniteElement/lnInclude -DCELL_DECOMP -I/home/hjasak/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -pthread -c $SOURCE -o Make/linuxGcc4DPOpt/freeSurface.o
Hrv
Hrvoje Jasak
Old   September 30, 2006, 17:35
Default Thanks Mr. Hrvoje Jasak for yo
mer
merrouche djemai
Thanks Mr. Hrvoje Jasak for your replay.
First, excuse me. I made a mistake about the file in my post. Yes, it is freeSurface.c.
secondly, The objectif behind my compilation of this solver is to understand the bubbleInterTrackFoam solver which needs (if I'm right) the freeSurface library. In my case, I don't compile your development version at all, but copy the solver in the released version of openFoam-1.3, then the error appears.
The final object, is to translate this with the interFoam solver. if you ask me, why I'm doing so, I responde you that: first I'm a new user of CFD and openFoam and I try to developp a script of coupling which couple between some solvers within openFoam without a major modification in the solvers.
Thanks you.
Merrouche
Old   October 1, 2006, 10:07
Default Hi, Here is the result of m
mer
merrouche djemai
Here is the result of my compilation.
Making dependency list for source file freeSurface.C
Making dependency list for source file makeFreeSurfaceData.C
Making dependency list for source file freeSurfacePointDisplacement.C
SOURCE_DIR=.
SOURCE=freeSurface.C ; g++ -m32 -Dlinux -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-30 -I/home/mer/OpenFOAM/OpenFOAM-1.3/src/finiteArea/lnInclude -I/home/mer/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude -I/home/mer/OpenFOAM/OpenFOAM-1.3/src/dynamicMesh/lnInclude -I/home/mer/OpenFOAM/OpenFOAM-1.3/src/tetDecompositionMotionSolver/lnInclude -I/home/mer/OpenFOAM/OpenFOAM-1.3/src/tetDecompositionFiniteElement/lnInclude -DFACE_DECOMP -I/home/mer/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -pthread -c $SOURCE -o Make/linuxGcc4DPOpt/freeSurface.o
freeSurface.C: In member function 'void Foam::freeSurface::smooth()':
freeSurface.C:1390: error: 'class Foam::tetDecompositionMotionSolver' has no member named 'twoDMotion'
make: *** [Make/linuxGcc4DPOpt/freeSurface.o] Error 1
I can see a difference between yours in : -DCELL_DECOMP and DFACE_DECOMP. any help?
Thanks.
[OpenFOAM] SnapShot appears as Black image maruthamuthu_venkatraman ParaView 2 January 30, 2009 04:22
Warning appears Johnpeter FLUENT 0 July 13, 2007 13:01
Why Strouhal no. appears in some NS eqns zonexo Main CFD Forum 2 July 28, 2006 10:55
Restart fails, .lck appears John CFX 2 April 29, 2005 10:12
Incontinuity appears at the grid interface Ryan FLUENT 4 April 23, 2004 05:13
