October 13, 2006, 14:03 |
Hi all,
is the following synt
Miriam
Rep Power: 17 |
Hi all,
is the following syntax correct? fvMatrix pEqn ( G1*fvm::div(phi,p) - G2*fvm::laplacian(p) - fvm::Sp(F(p)) ); solve(pEqn); where p is a field that has to be calculated G1 is a funcion of x,y,z (mesh coordinates) G2 is a geometricField already calculated F(p) is a function of the field that has to be calculated Besides if U is a volVectorField which is Known and c is a volScalarField that has to be determined can I write fvm::div(U,c)? Thanks in advance Bye Miriam |
Syntax Error | Virag | CFX | 4 | February 3, 2019 08:59 |
Syntax Error | Mechstud | CFX | 3 | June 29, 2007 08:22 |
Syntax | r2d2 | OpenFOAM | 1 | December 13, 2005 14:19 |
Syntax What does mean | evgenii | OpenFOAM Pre-Processing | 2 | November 23, 2005 09:42 |
UDF syntax error | Duc | FLUENT | 2 | June 11, 2002 10:27 |
