Calculation of phi if velocity field is known
Old   October 14, 2006, 18:14
Default Hello, I have a quick quest
Ankur Gupta
ankgupta8um is on a distinguished road
I have a quick question on the calculation of 'phi' -
I am using a modified channelOodles solver. I have two mesh regions in my domain. I am solving for the flow in first mesh region. I want to solve for the transport of a scalar in my second mesh region, where I would like to have the same phi field as that of mesh 1.
Is it okay to just copy the velocity field from region 1 to region 2 (for some reasons I can't copy the phi field directly) and calculate phi2 as follows:
phi2 = (fvc::interpolate(U2) & mesh2.Sf());
Please comment on my approach !!
Thanks!
Regards,
Ankur
ankgupta8um is offline   Reply With Quote
Old   October 15, 2006, 02:47
Default Pretty bad. If you want to se
Hrvoje Jasak
Pretty bad. If you want to see how bad it is, check the mass conservation on your second mesh.
You have to do much better than this, otherwise you will have boundedness problems in the scalar transport.
Hrv
Hrvoje Jasak
Old   October 15, 2006, 03:11
Default Hello Hrv, Could you please
Ankur Gupta
Hello Hrv,
Could you please suggest me something (to copy velocity field from mesh 1 to mesh 2) with which I can get accurate answers while solving for scalar transport ??
Thanks!
Regards,
Ankur
Old   October 15, 2006, 03:32
Default Yes I can. In order to get co
Hrvoje Jasak
Yes I can. In order to get conservative fluxes you will need to solve the pressure equation again on the new mesh - there is no other way of ensuring mass conservation.
On balance, I would say you are (much) better off solving the scalar transport on the same mesh. However, if you have no choice, have a look at my Thesis and you will find the details. There, I was doing adaptive mesh refinement (in FOAM, of course!) and show how to interpolate the components and solve the pressure equation to get mass conservation.
Enjoy,
Hrv
Hrvoje Jasak
Old   October 15, 2006, 03:59
Default Hello Hrv, Thanks for the r
Ankur Gupta
Hello Hrv,
Thanks for the reply.
Here, I would like to mention something that I think I should have said before.
Mesh 2 in my case is exactly twice of mesh 1 (Mesh 1 is a channel, mesh 2 is also a channel. Length of channel 2 is twice that of channel 1. Consider channel 2 to be of two parts - each part exactly equivalent to channel 1). My streamwise BC is periodic for channel 1, so basically I can just copy the velocity field of channel 1 to the two-parts of channel 2.
So, if I am using the converged velocity field of channel 1 to get phi for channel 2, would I still have some mass conservation issues while solving scalar transport for mesh 2 ??
Regards,
Ankur
Old   October 15, 2006, 04:46
Default You cannot copy the cell centr
Hrvoje Jasak
You cannot copy the cell centre velocity and interpolate it because you will have a mass conservation error. If the two meshes match exactly, you could find face correspondence between the two meshes (they basically need to be identical) and map that. In all other cases, you need to solve the pressure equation.
In any case, do whatever you think is good, calculate the flux divergence in each cell and compare it with the divergence of fluxes on the first mesh. That will tell you how wel you are doing - if the fluxes are not conservative, you will have trouble with scalar transport.
Hrv
Hrvoje Jasak
How to get Pressure field from velocity field qunwuhe@hotmail.com Main CFD Forum 4 October 14, 2007 08:38
Run UDS with given velocity field! williams FLUENT 2 June 1, 2007 13:34
Electric Field calculation JamesT Phoenics 5 May 31, 2007 05:44
velocity field Faiz Ahmed Main CFD Forum 0 March 5, 2006 11:11
Zero velocity field gianluca FLUENT 0 November 29, 2004 11:10
