Strange epsilon
Old   September 13, 2006, 04:23
Default I am running a simulation with
chris book
chris1980 is on a distinguished road
I am running a simulation with the standart k-epsilon model. I have specified an initial condition for k=9.5 and epsilon=1750. However the volume averaged epsilon after the first time step is <epsilon> = 3700!
Can anybody shed some light into it why the volume averaged epsilon is some much different form the initial condition?
chris1980 is offline   Reply With Quote
Old   September 13, 2006, 06:53
Default That's because your turbelence
Hrvoje Jasak
That's because your turbelence is huge! Your velocity FLUCTUATION is 3.5 m/s - this is the speed I have trouble to walk on. Assuming turbulence intensity of 1%, your mean velocity would be the speed of sound (with a lot of turbulence).
I would revisit my initial condition, it does not look right.
Hrv
Hrvoje Jasak
Old   September 13, 2006, 07:12
Default Hrv, I think a velocity flu
chris book
Hrv,
I think a velocity fluctuation of 3.5 m/s corresponds not to k=9.4 m^2/s^2, instead a fluctuation of 2.52 m/s is right.
Do you agree ?
The turbulence data (velocity fluctuation, integral lengthscale) comes from a experimental turbulence generator (multihole plate) with an integral lenghtscale of 3mm.
In the experiment I want to simulate there is almost no mean flow but there is a sort of background turbulence created by the turbulence generator.
So do you still think there is a incorrect initial condition?
Old   September 13, 2006, 07:17
Default Ah, OK: if you have a turbulen
Hrvoje Jasak
Ah, OK: if you have a turbulence generator and experiments, this may well be right. In that case, you should just let the flow develop and the model should do its job. As for k, I probably made a mistake:
k = 3/2 uPrime^2
I should have said 2.5 m/s, i.e walking speed :-)
Hrv
Hrvoje Jasak
Old   September 13, 2006, 08:58
Default Hi, Epsilon usually scales
Ola Widlund
olwi is on a distinguished road
Epsilon usually scales something like K^1.5/(0.3*L). In your case this is 3e4. In that light the value after one time step is not very high, rather your initial value is very small.
/Ola
olwi is offline   Reply With Quote
Old   September 13, 2006, 10:03
Default ok but the same case running w
chris book
ok but the same case running with star give me averaged epsilons from 2000..6000! So I don't know where the big difference gomes into the game
Old   October 24, 2006, 10:05
Default What is resonable choice for e
chris book
What is resonable choice for epsilon (I use the compressible RNG-k-epilon model) in the case of no initial turbulence (i.e. k=1e-8)?
Strange boundaries for k and epsilon henning OpenFOAM Running, Solving & CFD 4 January 7, 2009 03:54
Strange boundaries for k and epsilon henning OpenFOAM Running, Solving & CFD 0 December 16, 2008 09:42
Strange boundaries for k and epsilon henning OpenFOAM Running, Solving & CFD 0 December 16, 2008 09:34
derivation of epsilon equation of k-epsilon model Ricardo Rezende Main CFD Forum 5 May 1, 2007 06:38
Strange ? bob FLUENT 1 May 12, 2004 04:16
