Layer addtionremoval turbulence properties
Old   December 5, 2006, 05:31
Default I have implemented the layer a
stefan
stefanke is on a distinguished road
I have implemented the layer addition/removal feature into the existing engine solver (engineFoam/dieselEngineFoam). The layer addition/removal itself (pure mesh motion) works fine. I have to stress that my faceZone is a 4 Layers away from the piston (so I do not use the piston surface).
A strange thing happens in the expansion stroke:
Crank angle = 30 CA-deg
Mean u':1.67458
-> switching from deformation mode into layering mode
Crank angle = 30.0099 CA-deg
Mean u':5.36223
Crank angle = 30.0103 CA-deg
Mean u':11.4833
Crank angle = 30.0107 CA-deg
Mean u':32.7286
-> solver blows up
Why does u' increase? Are there any special things to know?
A helping hand is very appreciated
stefanke is offline   Reply With Quote
Old   December 5, 2006, 09:04
Default some additional information:
stefan
the turbulence instensity increases unphysically (see my last posting) as soon as the first layer is added. So something goes wrong in the layer addition and that's causing my solver to blow up!
In the compression stroke (layer removal) all works well.
Any ideas?
Old   December 5, 2006, 09:14
Default A comment (this is known stuff
Hrvoje Jasak
A comment (this is known stuff): if you are throwing away the layer next to the wall, where wall functions operate, you keep throwing away your boundary layer. Consider removing a cell layer away from the wall.
Hrv
Hrvoje Jasak
Old   December 5, 2006, 09:33
Default Thanks Hrv for you respond.
stefan
As I have said before I do not use a faceZone which corresponds to a wall boundary (e.g. piston surface). I have defined my faceZone on top of the static part (piston+3 layers) si the cell layer is away from a wall. Ok there are some cells in the layer touching liner but this should be ok. Any more ideas?
Turbulence Properties set to on or off sven82 OpenFOAM Running, Solving & CFD 3 November 18, 2008 06:03
Free air turbulence properties Luis Díaz FLUENT 0 March 15, 2008 04:23
Fluent turbulence properties? prasat FLUENT 8 August 26, 2003 14:53
turbulence properties (k, epsilon) with v.o.f. ? song FLUENT 0 February 27, 2003 21:21
UDF & Accessing Turbulence Properties Dimal FLUENT 0 March 5, 2002 14:14
