December 11, 2006, 16:10 |
I am trying to simulate water
Rep Power: 17 |
I am trying to simulate water drop (of diameter D) in moving air. For this purpose, I would like to solve a flow field and introduce a liquid drop into the system.
I see that boxtoCell would create a box type patch..how can I create a spherical fluid patch. If my case is axisymmetric what should I use? I also did see the rotatedboxtoCell but not sure if its the right thing to use. |
December 12, 2006, 02:23 |
HI:
i am also interested in
HI:
i am also interested in the question.there are lots of branches in TopoSetValue.could anyone explain how to use these utilities |
December 12, 2006, 04:13 |
You'll have to create your own
Mattijs Janssens
Rep Power: 26 |
You'll have to create your own code to generate and write out a faceSet (which can then be used to make a patch). (the faceSet application with the boxToFace, rotatedBoxToFace etc. sources just handles the most general cases)
faceSets are very easy to code, e.g. // Generate faceSet called f0 with size 100 faceSet f0(mesh, "f0", 100); // Add faces based on face centre forAll(mesh.faceCentres(), faceI) { if (mesh.faceCentres()[faceI].x() < 0) { f0.insert(faceI); } } // Write to file f0.write(); |
December 12, 2006, 05:08 |
hi Mattijs:thanks
but i jus
hi Mattijs:thanks
but i just want to set a circul cylinder inside the hydrocylone which i want to patch a air-core,is there any basic sources ?how can i use them? thankS! |
Transient interFoam with MRF | jaswi | OpenFOAM Running, Solving & CFD | 18 | October 21, 2011 00:29 |
HELP NEEDED HOW TO MAP VALUES FROM PATCH OF ONE MESH TO PATCH OF ANOTHER MESH | mkraposhin | OpenFOAM Running, Solving & CFD | 3 | September 4, 2011 10:42 |
Runing InterFoam for 3 D damBreak case Patch issue | nishant_hull | OpenFOAM Running, Solving & CFD | 5 | February 18, 2009 01:32 |
InterFoam | floooo | OpenFOAM Running, Solving & CFD | 0 | November 3, 2008 12:00 |
Ask for a Phd thesis about interFoam | zjucfd | OpenFOAM Running, Solving & CFD | 1 | July 3, 2007 12:10 |
