Inhomogenous two fluid model with mixing fluids |
January 8, 2007, 13:09 |
Hi all,
is there any solver
Volker Kaufmann
Rep Power: 17 |
Hi all,
is there any solver which can handle mixing fluids calculating a velocity field for each phase? Means something like bubbleFoam but without the restriction of one phase to be disperse. In twoLiquidMixingFoam a homogeneous approach seems to be implemented, right? If there's no solver, how is this restriction in bubbleFoam implemented or is it possible to modify twoLiquidMixingFoam in an appropriate way? Thanx a lot in advance. Volker |
Mixing different fluids | Isabel | FLUENT | 1 | October 22, 2010 17:53 |
mixing two fluids using mixture model | fadhil | FLUENT | 0 | June 9, 2008 02:28 |
Mixing two fluids | Rajat | FLUENT | 3 | January 21, 2007 20:19 |
Inhomogeneous two fluid model with mixing fluids | vkaufmann | OpenFOAM Running, Solving & CFD | 4 | January 8, 2007 15:44 |
Inhomogenous two fluid model with mixing fluids | vkaufmann | OpenFOAM Running, Solving & CFD | 0 | January 8, 2007 13:12 |
