Inhomogeneous two fluid model with mixing fluids |
January 8, 2007, 13:14 |
Hi all,
is there any solver
Volker Kaufmann
Rep Power: 17 |
Hi all,
is there any solver which can handle mixing fluids calculating a velocity field for each phase? Means something like bubbleFoam but without the restriction of one phase to be disperse. In twoLiquidMixingFoam a homogeneous approach seems to be implemented, right? If there's no solver, how is this restriction in bubbleFoam implemented or is it possible to modify twoLiquidMixingFoam in an appropriate way? Thanx a lot in advance. Volker |
January 8, 2007, 13:30 |
"without the restriction of on
Srinath Madhavan (a.k.a pUl|)
Rep Power: 21 |
"without the restriction of one phase to be disperse"
Just what kind of flow pattern are we talking about here? Stratified? |
January 8, 2007, 13:46 |
The whole thing is about flow
Volker Kaufmann
Rep Power: 17 |
The whole thing is about flow regime transition of bubbly flows in vertical pipes. So the flow patterns vary between disperse bubbly flow to slug/churn flow. I'm trying to model the interfacial area density in these flows. A homogeneous approach will not work as you cannot assume the velocity field to be equal for both phases.
January 8, 2007, 14:05 |
I guess bubblefoam or twoPhase
Rep Power: 21 |
I guess bubblefoam or twoPhaseEulerFoam is the proper starting point. You will certainly need a Population balance model to properly account for bubble breakage and coalescence since you are interested in interfacial area density.
Oh and here is a reference I remember from my Masters: Navarro-Valenti, S., R. T. Lahey Jr., D. A. Drew and M. Mills, "Two-fluid modeling of the bubbly/slug flow regime transition", Transactions of the American Nuclear Society Winter Meeting, 69, 495-496 (1993). |
January 8, 2007, 15:44 |
bubbleFoam and twoPhas
Alberto Passalacqua
Rep Power: 36 |
bubbleFoam and twoPhaseEulerFoam are solvers based on the Eulerian-Eulerian two fluid approach. So they should be suitable for your purpose. A momentum equation is solved for both phases, so you're not assuming the same velocity field for the phases. You may need to change the turbulence model, if you need something more advanced than the mixture model implemented at the moment. Regards, Alberto
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
Mixing different fluids | Isabel | FLUENT | 1 | October 22, 2010 17:53 |
mixing two fluids using mixture model | fadhil | FLUENT | 0 | June 9, 2008 02:28 |
Mixing two fluids | Rajat | FLUENT | 3 | January 21, 2007 20:19 |
Inhomogenous two fluid model with mixing fluids | vkaufmann | OpenFOAM Running, Solving & CFD | 0 | January 8, 2007 13:12 |
Inhomogenous two fluid model with mixing fluids | vkaufmann | OpenFOAM Running, Solving & CFD | 0 | January 8, 2007 13:09 |
