IcoTopoFoam case is aborted
Old   July 9, 2006, 11:55
Default Hi Hrv, I have chosen a sec
  #21
rafal zietara
rafal is on a distinguished road
Hi Hrv,
I have chosen a second option:
Extending the cylindrical sliding interface in vertical directions – this works very good (no errors, nice distribution of parameters). However I showed only a simplified case. On the top of my mixer i have something that will not "like" moving mesh topology so this solution is not suitable for me.
I concentrated on one sliding interface out of both sliders. This is something i am working on now and it is causing problems indeed.
Now I am diving in the code to understand better what is happening. I have still several things to check. If i manage to make it work i will post a solution. it may take me however 2-3 weeks (from Tuesday i'm on holiday in hot country not in Rainchester ).
Thanks for suggestions.
rafal
rafal is offline   Reply With Quote
Old   July 9, 2006, 17:24
Default Hehe, Rainchester: I know exac
  #22
Hrvoje Jasak
Hehe, Rainchester: I know exactly what you mean.
To be honest with you, I need encouragement and/or company to get this finished and it's quite a hard job. I am trying to assemble a group of people who can either join in or contribute in other ways to get this work restarted. For all those out there who need sliding interfaces, complex topo changes and parallelism, now is the time to join in.
In any case, give me a shout when you come back to the real world and we can look for a way to take this further.
Have a good holiday,
Hrv
Hrvoje Jasak
Old   November 13, 2006, 04:43
Default Dear FOAM community, I'm ha
  #23
Mikko Auvinen
auvinen is on a distinguished road
I'm having a terrible time producing anything with icoDyMFoam. I cannot even reproduce the example cases delivered in this forum (kupplung, mixer3D). Okay, mixer2D ran fine. I do need some help for I'm from the Fortran community and a newbie to OpenFOAM.
1.) Case Kupplung runs until Time = 0.00573, but not beyond no matter what I do. The dramatic dying moment is captured here:
Mean and max Courant Numbers = 1.83329e-05 0.000287003
Time = 0.005729
ICCG: Solving for pcorr, Initial residual = 1, Final residual = 9.17333e-09, No Iterations 87
ICCG: Solving for pcorr, Initial residual = 0.0285899, Final residual = 6.106e-09, No Iterations 66
time step continuity errors : sum local = 1.40674e-20, global = 8.82553e-23, cumulative = 4.29905e-14
BICCG: Solving for Ux, Initial residual = 0.00324129, Final residual = 1.1653e-10, No Iterations 1
BICCG: Solving for Uy, Initial residual = 0.00317451, Final residual = 1.16643e-10, No Iterations 1
BICCG: Solving for Uz, Initial residual = 0.000524492, Final residual = 1.53121e-11, No Iterations 1
ICCG: Solving for p, Initial residual = 0.00444813, Final residual = 9.78411e-08, No Iterations 39
ICCG: Solving for p, Initial residual = 7.57075e-06, Final residual = 8.85904e-08, No Iterations 6
time step continuity errors : sum local = 3.72149e-14, global = -9.21735e-16, cumulative = 4.20687e-14
ICCG: Solving for p, Initial residual = 1.35521e-07, Final residual = 7.30238e-08, No Iterations 1
ICCG: Solving for p, Initial residual = 7.307e-08, Final residual = 7.307e-08, No Iterations 0
time step continuity errors : sum local = 3.06951e-14, global = -5.79509e-16, cumulative = 4.14892e-14
ICCG: Solving for p, Initial residual = 7.30763e-08, Final residual = 7.30763e-08, No Iterations 0
time step continuity errors : sum local = 3.06978e-14, global = -5.79044e-16, cumulative = 4.09102e-14
time step continuity errors : sum local = 3.06978e-14, global = -5.79043e-16, cumulative = 4.03312e-14
ExecutionTime = 27.52 s ClockTime = 28 s
Mean and max Courant Numbers = 1.83367e-05 0.000287053
Time = 0.00573
ICCG: Solving for pcorr: solution singularity
time step continuity errors : sum local = nan, global = nan, cumulative = nan
BICCG: Solving for Ux: solution singularity
BICCG: Solving for Uy: solution singularity
BICCG: Solving for Uz: solution singularity
ICCG: Solving for p: solution singularity
ExecutionTime = 28.34 s ClockTime = 29 s
Mean and max Courant Numbers = nan 0.000287104
Time = 0.005731
Foam::error::printStack(Foam:stream&)
Foam::sigSegv::sigSegvHandler(int)
/lib64/libc.so.6 [0x30ca22ee80]
Foam::Field<double>::map(Foam::UList<double> const&, Foam::FieldMapper const&)
Foam::Field<double>::autoMap(Foam::FieldMapper const&)
void Foam::MapGeometricFields<double,>(Foam::fvMeshMapp er const&)
Foam::fvMesh::mapFields(Foam::mapPolyMesh const&)
Foam::fvMesh::updateMesh(Foam::mapPolyMesh const&)
Foam::polyTopoChanger::changeMesh()
Foam::mixerFvMesh::update()
icoDyMFoam [0x41497b]
__libc_start_main
__gxx_personality_v0
Segmentation fault
___________________________________________
2.) Mixer3D on the other hand meets its fatal end at the first time step. Here is the restart from latestTime:
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.3 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : icoDyMFoam . mixer3D
Root : /home/mauvinen/OpenFOAM/mauvinen-1.3/run/cases
Case : mixer3D
Nprocs : 1
Create time
Create mesh
Selecting dynamicFvMesh mixerFvMesh
void mixerFvMesh::addZonesAndModifiers() : Zones and modifiers already present. Skipping.
Mixer mesh:
origin: (0 0 0)
axis: (0 0 1)
rpm: 10
Reading transportProperties
Reading field p
Reading field U
ICCG: Solving for pcorr, Initial residual = 1, Final residual = 6.59728e-09, No Iterations 73
ICCG: Solving for pcorr, Initial residual = 0.000170241, Final residual = 8.33034e-09, No Iterations 46
time step continuity errors : sum local = 5.20285e-14, global = 4.66565e-22, cumulative = 4.66565e-22
Starting time loop
Mean and max Courant Numbers = 0.000225328 0.00300178
deltaT = 0.000595238
Time = 2.0006
ICCG: Solving for pcorr, Initial residual = 1, Final residual = 6.66178e-09, No Iterations 73
ICCG: Solving for pcorr, Initial residual = 0.000397392, Final residual = 9.09398e-09, No Iterations 48
time step continuity errors : sum local = 3.84912e-12, global = 7.8478e-22, cumulative = 1.25134e-21
BICCG: Solving for Ux, Initial residual = 0.000881017, Final residual = 3.12e-09, No Iterations 1
BICCG: Solving for Uy, Initial residual = 0.000881708, Final residual = 3.04676e-09, No Iterations 1
BICCG: Solving for Uz, Initial residual = 0.00101462, Final residual = 4.41322e-09, No Iterations 1
ICCG: Solving for p, Initial residual = 0.990379, Final residual = 9.22838e-07, No Iterations 67
ICCG: Solving for p, Initial residual = 0.0157626, Final residual = 6.4386e-07, No Iterations 48
time step continuity errors : sum local = 1.3987e-10, global = 2.30073e-21, cumulative = 3.55208e-21
--> FOAM FATAL ERROR : Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
From function adjustPhi(surfaceScalarField& phi, const volVectorField& U,const volScalarField& p
in file cfdTools/general/adjustPhi/adjustPhi.C at line 108.
FOAM exiting
Any help on this matter would be highly appreciated. I'm studying fairly complex pump simulations with our own code and I'd like to replicate some of our cases with OpenFOAM. If only I could get past these problems ...
- mikko
auvinen is offline   Reply With Quote
Old   November 13, 2006, 07:34
Default Have a look through the forum:
  #24
Hrvoje Jasak
Have a look through the forum: the last sourceforge release is riddled with bugs and you need a patched up version.
Hrv
Hrvoje Jasak
Old   January 26, 2007, 06:18
Default Hi all, can someone send me th
  #25
clo
clo
clo is on a distinguished road
Hi all, can someone send me the mixer3D case that works with icoDyMFoam? As Mikko saied the case crash and I have the latest version...
thank you!
clo is offline   Reply With Quote
Old   December 2, 2010, 15:20
Thumbs up Problem now finally solved
  #26
Oliver Borm
deepblue17 is on a distinguished road
With the latest commit of the overlapGgi boundary condition in the OpenFOAM-1.6-ext git repository, this problem is now finally solved for me.
Thanks,
Oliver
deepblue17 is offline   Reply With Quote
partcle tracking (aborted trapped incomplete) Fabrizio FLUENT 4 September 21, 2007 13:15
No icotopoFoam alice OpenFOAM Running, Solving & CFD 0 August 17, 2007 06:58
IcoTopoFoam derath OpenFOAM 1 April 25, 2006 09:23
IcoTopoFoam giampippetto OpenFOAM Running, Solving & CFD 4 March 22, 2006 06:34
Reg "DPM-particle aborted" GANESH FLUENT 3 March 7, 2006 10:45
