TwoLiquidMixingFoam
Old   July 16, 2011, 03:10
Alberto Passalacqua
The version of twoLiquidMixingFoam in OpenFOAM 2.0 already uses PIMPLE. A tutorial was added today to 2.0.x (in git repository). Maybe take a look.
Best,
Alberto Passalacqua
Old   July 16, 2011, 04:03
Gijsbert Wierink
gwierink is on a distinguished road
Hi Tanay,
It would be helpful to post the compile error. But just guessing from
Originally Posted by Tanay View Post
surfaceScalarField muEff ("muEff", (alpha1*mu1 + (scalar(1)-alpha1)*mu2));
volScalarField rho ("rho", (alpha1*rho1 + (scalar(1)-alpha1)*rho2));
surfaceScalarField rhoIntoPhi ("rhoIntoPhi", rho*phi);
it seems that at least one of the problems is that you're trying to assign a volScalarField (rho) to something that is a surfaceScalarField (rhoIntoPhi). You can make rho into a surfaceScalarField for example by:
surfaceScalarField rhof = fvc::interpolate(rho);
surfaceScalarField rhoIntoPhi ("rhoIntoPhi", rhof*phi);
Hope that is of any help
EDIT: Whoops, missed Alberto's post. Well, hope it is helpful anyway
Regards, Gijs
gwierink is offline   Reply With Quote
Old   June 19, 2012, 09:50
okroud is on a distinguished road
Here's the fvSchemes file if anyone wishes to view it-
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
grad(U) Gauss linear;
grad(muEff) Gauss linear;
grad(p_rgh) Gauss linear;
snGradSchemes
default corrected;
divSchemes
default none;
div(phi,U) Gauss limitedLinearV 1;
div(phi,k) Gauss limitedLinear 1;
div(phi,epsilon) Gauss limitedLinear 1;
div(phi,R) Gauss limitedLinear 1;
div(R) Gauss linear;
div(phi,nuTilda) Gauss limitedLinear 1;
div((nuEff*dev(grad(U).T()))) Gauss linear;
div(phi,alpha1) Gauss limitedLinear 1;
div(phi) Gauss limitedLinear 1;
div(rhoPhi,U) Gauss limitedLinear 1;
div(rho*phi,U) Gauss limitedLinear 1;
It's long ago, but do you still know why you have set
And not limitedLinear 1 like all the other divSchemes. I know Gauss limitedLinear 1 exactly doesn't work (which is actually my problem), but isn't there a similar Scheme like limitedLinearV1 oder limitedLinear phi that works for div((nuEff*dev(grad(U).T())))?
okroud is offline   Reply With Quote
Old   June 19, 2012, 10:01
Balkrishna Patankar
balkrishna is on a distinguished road
According to the documentation , OpenFOAM doc
A limitedLinear scheme based on a flux phi with  is specified as default by phi = 1.
In ur definition, "div((nuEff*dev(grad(U).T()))) " there is no phi involved.
Probably , thats why Gauss limited linear doesnt work.
balkrishna is offline   Reply With Quote
Old   September 26, 2013, 01:22
Default two liquid mixing in a pipe flow
  #45
Carlos Alberto Flórez Arias
carlosfloar is on a distinguished road
Hi, I'm a master student who works about the mixing of two liquids in batching transport in a long pipes. I need to use a moving mesh because the high computational cost involved in the solutión of the entire domain. I want to use openFOAM for the solution of that problem specificaly employing the solver twoliquidmixingFoam. żIt is possible to do?
thanks in advance for your help.
carlosfloar is offline   Reply With Quote
Old   September 26, 2013, 12:44
Mieszko Młody
ziemowitzima is on a distinguished road
What kind of flow, are u planning to model ? Turbulent one, what is your Re ?
Do you mean ADAPTIVE MESH or MOVING mesh (changing geometry of the domain).
Both are possible. Did you look in this forum ?
Best
ziemowitzima is offline   Reply With Quote
Old   September 26, 2013, 20:00
I try to model a turbulent flow with Reynolds about 40000, I need to use moving mesh because the extension of the pipe, too many km and my interest is centered in the mixed fluid. At the moment I use a libraries written in c++ to attempt to solve this problem but I want to use OpenFOAM to solve it. żAnybody can help me with this? please, documentation, examples, tutorials...
Old   November 4, 2013, 13:59
Christiano Molossi
m.Chrsitiano is on a distinguished road
Hi everyone,
How do I know what equations that twoLiquidMixingFoam uses?
For exemple, if I set no turbulence model (laminar), where is the laplacian term in the UEqn? And where the solver uses the kinematic viscosity (nu)?
Any replay would be very helpful, since I've just started using OpenFOAM.
Best regards!
m.Chrsitiano is offline   Reply With Quote
Old   November 4, 2013, 14:14
Mieszko Młody
In the folder "system" in the file:
turbulenceProperties
you can set desired turbulence model. If you choose: laminar,
then standard N-S equations will be solved without any turbulence model, namely in the U eqn:
fvVectorMatrix UEqn
fvm::ddt(U)
+ fvm::div(phi, U)
+ turbulence->divDevReff(U)
the diffusion term
will be "replaced" by :
laplacian(nu,U)
where nu is your viscosity
if you choose e.g.:
simulationType RASModel;
then you have to have one more file in "system":
RASproperties
then in
corresponding turbulence model will be solved
see some of the examples in the tutorial/run/.../cases
Old   November 4, 2013, 14:46
Christiano Molossi
Thank you very much! It was very enlightening!
Now make sense to me.
One more thing, about transport equation, where am I able to find it? Where is the file that it is writing?
Thank you very much again for your attention!
Old   November 4, 2013, 15:53
Mieszko Młody
every solver is located at:
/opt/openfoam210/applications/solvers
or sth similar depending what version of OF and what OS you have.
see
http://openfoamwiki.net/index.php/Main_Page
and
http://openfoamwiki.net/index.php/IcoFoam
best
Old   November 5, 2013, 11:55
Christiano Molossi
Thanks for the answer, that will be a nice help for me to work on.
Old   January 14, 2014, 18:43
Default schemes for alpha1
  #53
hi
I want to ask about the alphaDiffusionEqn.H file, in that file what's the meaning of the second line in:
fvm::ddt(alpha1)
- fvc::ddt(alpha1)
- fvm::laplacian
volScalarField("Dab", Dab + alphatab*turbulence->nut()),
alpha1
I think the meaning of the first line, fvm::ddt(alpha1) is (((rho_P*alpha1_P)^n)-((rho_P*alpha1_P)^o))/(Delta t)
it's this right? and, the second line?
please help me!!
Old   January 22, 2014, 15:39
Default twoLiquidMixingDyMFoam
  #54
hi, I'm working in the implementation of Dynamic mesh in twoLiquidMixingFoam solver, I'm stuck at the moment, I try to use InterDyMFoam for a guide but don't obtain any results....any suggestions?
Old   January 23, 2014, 22:20
  #55
I want to simulate a parcel composed of two fluids moving with the mean flow velocity, I try to implement DyM twoLiquidMixingFoam, but when I try to simulate a case the delta of time begins to decrease until it finally stops the solution ... I use a Courant=0.1 ,I initially tested on lockForExchange with boundary conditions fixedValue=0 on the walls ..... any suggestions?
Old   February 19, 2014, 14:38
Default LES model
  #56
Christiano Molossi
Hello everyone,
How can i implement the LES model in the solver twoLiquidMixingFoam?
Old   March 20, 2014, 13:41
Default fvSchemes
  #57
Christiano Molossi
Hey guys,
Nobody know how to setup the solver to LES?
Another thing is, how do i change the numerical schemes in the fvSchems file? For exemple, the InterpolationSchemes?
Please, i would be very greatful for any replay.
Thank you in advance,
Christiano.
Old   June 25, 2014, 14:26
  #58
Hi, I implemented the funcionality of dynamic mesh in the solver twoLiquidMixingFoam to solve the mixing of two fluids in a pipeline tracking a control volume of the domain large enough so that the interface between the two liquids is always contained therein. I ran tests with both sovers, twoLiquidMixingFoam and "twoLiquidMixingDyMFoam" but when comparing the amount of liquid that is mixed, it is rather more with the solver twoLiquidMixingDyMFoam. I use the same configuration in both solvers, the same fvSchemes, fvSolution, etc. anyone can help me with the Dynamic Mesh error?
Old   September 23, 2014, 14:50
Default Front Velocity
  #59
Christiano Molossi
Hello again people,
I was wondering...
How do you guys do to calculate the front velocity from a gravity current simulation?
Old   December 8, 2014, 07:35
Question Regarding Kinematic Viscosity
  #60
Himanshu Sharma
himanshu28 is on a distinguished road
Hi ziemowitzima,
your reply was useful but since there are two fluids and in the transport property file we specify kinematic viscosity of both the fluid,hence my question is which fluid kinematic viscosity will be used to solve the UEqn.
will be weighted same as density ----> rho = rho_1*alpha1 +rho_2*(1-alpha_1)
as there are nothing being mentioned on this part.
Thank you
Originally Posted by ziemowitzima View Post
fvVectorMatrix UEqn
fvm::ddt(U)
+ fvm::div(phi, U)
the diffusion term
laplacian(nu,U)
if you choose e.g.:
RASproperties
then in
himanshu28 is offline   Reply With Quote
