January 28, 2007, 11:02 |
Hi all,
I need to check conv
Hi all,
I need to check convergence behavior of my calculations using root-mean-square residuals. What I need is to calculate residuals before (and after) solving the fvMatrix. fvVectorMatrix UEqn ( fvm::div(phi, U) // - fvm::Sp(fvc::div(phi), U) + turbulence->divRhoR(U) == -fvc::grad(p) ); UEqn.relax(); vectorField U_residual = UEqn.residual(); scalarField u_residual = U_residual.component(0); Info << " Normalized Initial U L2 Residuals : " << Foam::sqrt(sum(sqr(u_residual*massIn/uin))) << endl; UEqn.solve(); U_residual = UEqn.residual(); Info << " Normalized Initial U L2 Residuals : " << Foam::sqrt(sum(sqr(u_residual*massIn/uin))) << endl; ------- This structure works fine for fvScalarMatrix such as hentalpy,omega,k but fails in case of fvVectorMatrix: solution varies in case I calculate residuals before solving or not. Is there anyone that ever notice such a behavior? To my knowledge residual calculation does not change the matrix and so the solution. I looked up in the fvMatrixsolve.H at the implementation of the member residual and it doesn't seem (I have to tell that I'm not a master in reading FOAM yet) to modify the fvVectorMatrix. Is fvVectorMatrix.residual() influencing somehow the coefficients, is it just a bug or am I getting mad? I hope I have been clear enough to be understood. Thanks a lot for your answers Cosimo
Cosimo Bianchini Ergon Research s.r.l. Via Panciatichi, 92 50127 Florence - ITALY Tel: +39 055 0763716 Mob: +39 320 9460153 e-mail: cosimo.bianchini@ergonresearch.it URL: www.ergonresearch.it |
Cannot see residuals while solving | Dre | CFX | 3 | January 29, 2009 11:00 |
Why solving | kar | OpenFOAM Running, Solving & CFD | 2 | April 30, 2008 15:15 |
solving a Matrix | Behafarid | Main CFD Forum | 3 | September 9, 2006 23:14 |
Solving the Psystem | kupiainen | OpenFOAM Running, Solving & CFD | 3 | May 2, 2005 12:34 |
MHD solving? | Rajil Saraswat | Main CFD Forum | 1 | March 21, 2003 11:26 |
