FOAM FATAL ERROR Maximum number of iterations exceeded |
January 28, 2016, 03:05 |
#21 |
Baris (Heewa)
Rep Power: 13 |
Hi Francis,
Thank you for your advice. It also lets me solve my problem. BR. |
February 26, 2016, 11:37 |
#22 |
S Atkinson
Rep Power: 11 |
I am using a Cht K epsion model using Openfoam and I keep getting this error. I have tried changing the maxiter to 10000 and still get the problem too. Did anyone get to the bottom of this? I completely remade my mesh and still get this same error although I have a few overly skewed faces (64 failed skewness faces) and 900 faces failing nonOrthag check, however due to the geometry even if I used SHM these errors would still occur. I tried Francis's method and this has't solved it. I have noticed a sharp (impossible) rise in density in certain regions of the fluid, this was so sharp that it shouted alarm. However I am unfamiliar with this type of modelling so thought I would ask for some advice. I previously attended the Advanced Openfoam training course and have emailed the guy who ran it (as has my work mate) regarding problems which he encouraged. Unfortunately he does not respond to emails, which has left me a bit discouraged. Cheers |
June 28, 2016, 06:27 |
#23 |
Moritz
Rep Power: 10 |
Hey everyone,
I recently ran into the same issue using the sprayFoam solver with version OF2.4 and an implemented ignition. The error especially ocurrs when I ignite more than one cell and I think it must be due to the Newton solver used to calculate the temperature. Eventually it ocurrs with only one ingiting cell as well though. Has anyone solved this issue so far? @sahul could you provide the implented brent solver? Thanks in advance Moritz |
July 5, 2016, 10:34 |
#24 |
S Atkinson
Rep Power: 11 |
Hi Moritz,
Have you had any luck on this one? I have noticed that my temperatures are diverging too for no reason. I riginally solved the issue by switching to the plane wall 2d solver, however I have got the error again now. |
July 5, 2016, 15:53 |
#25 |
Henry
Rep Power: 10 |
I've been having a lot of trouble tracing the source of this error. I know it happens in the thermoI.H file, but I can't trace what is calling that, or figure out any reason why this is happening. I've had no luck trying to fix this on my own for a while now.
The case i am running is a simple wedge (meshed with snappy hex mesh) inside a blockmesh region using rhoCentral foam. any help would be really appreciated this is the error log file Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 3.0.1-119cac7e8750 Exec : rhoCentralFoam -parallel Date : Jul 01 2016 Time : 12:54:38 Host : "cfd01" PID : 30359 Case : /----/wedge15maxIterError nProcs : 36 Slaves : 35 ( "cfd01.30360" "cfd01.30361" "cfd01.30362" "cfd01.30363" "cfd01.30364" "cfd01.30365" "cfd01.30366" "cfd01.30367" "cfd01.30368" "cfd01.30369" "cfd01.30370" "cfd02.26571" "cfd02.26572" "cfd02.26573" "cfd02.26574" "cfd02.26575" "cfd02.26576" "cfd02.26577" "cfd02.26578" "cfd02.26579" "cfd02.26580" "cfd02.26581" "cfd02.26582" "cfd03.29133" "cfd03.29134" "cfd03.29135" "cfd03.29136" "cfd03.29137" "cfd03.29138" "cfd03.29139" "cfd03.29140" "cfd03.29141" "cfd03.29142" "cfd03.29143" "cfd03.29144" ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading thermophysical properties Selecting thermodynamics package { type hePsiThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } Reading field U Creating turbulence model Selecting turbulence model type laminar fluxScheme: Kurganov Starting time loop Mean and max Courant Numbers = 0.00521015 0.119072 deltaT = 2.4e-06 Time = 2.4e-06 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUz, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Ux, Initial residual = 0.999285, Final residual = 0.00389594, No Iterations 5 smoothSolver: Solving for Uy, Initial residual = 0.999999, Final residual = 8.69665e-17, No Iterations 5 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 8.81879e-17, No Iterations 5 diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for e, Initial residual = 1.46977e-11, Final residual = 1.46977e-11, No Iterations 0 ExecutionTime = 0.68 s ClockTime = 1 s Mean and max Courant Numbers = 0.00625242 0.142579 deltaT = 2.88e-06 Time = 5.28e-06 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUz, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Ux, Initial residual = 6.23273e-10, Final residual = 6.23273e-10, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 1.24042e-05, Final residual = 6.5351e-18, No Iterations 5 smoothSolver: Solving for Uz, Initial residual = 0.00028774, Final residual = 4.85118e-17, No Iterations 5 diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for e, Initial residual = 5.7298e-12, Final residual = 5.7298e-12, No Iterations 0 [0] [1] [1] [1] --> FOAM FATAL ERROR: [1] Maximum number of iterations exceeded [1] [1] From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar)const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar)const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar)const) const [with Thermo = Foam::hConstThermo<Foam::perfectGas<Foam::specie> >; Type = Foam::sensibleInternalEnergy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy>] [1] in file /home/openfoam/OpenFOAM/OpenFOAM-3.0.1/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 66. [1] FOAM parallel run aborting [1] [2] [2] [2] --> FOAM FATAL ERROR: [3] [3] [3] --> FOAM FATAL ERROR: [3] Maximum number of iterations exceeded [3] [3] From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar)const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar)const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar)const) const [with Thermo = Foam::hConstThermo<Foam::perfectGas<Foam::specie> >; Type = Foam::sensibleInternalEnergy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy>] [3] in file /home/openfoam/OpenFOAM/OpenFOAM-3.0.1/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 66[7] [7] [7] --> FOAM FATAL ERROR: [7] Maximum number of iterations exceeded [7] . p: Code:
dimensions [1 -1 -2 0 0 0 0]; internalField uniform 18822.7; boundaryField { inlet { type fixedValue; value uniform 18822.7; } outlet { type zeroGradient; } airplane { type zeroGradient; } bottom { type zeroGradient; } top { type zeroGradient; } symmetry { type symmetryPlane; } left { type zeroGradient; } defaultFaces { type zeroGradient; } } Code:
dimensions [0 0 0 1 0 0 0]; internalField uniform 216.65; boundaryField { inlet { type fixedValue; value uniform 216.65; } outlet { type zeroGradient; } airplane { type zeroGradient; } bottom { type zeroGradient; } top { type zeroGradient; } left { type zeroGradient; } symmetry { type symmetryPlane; } defaultFaces { type zeroGradient; } } Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (400 0 0); //(246.933 0 0); boundaryField { inlet { type fixedValue; value uniform (400 0 0); //(246.933 0 0); } outlet { type zeroGradient; } airplane { type slip; } bottom { type zeroGradient; } top { type zeroGradient; } left { type zeroGradient; } symmetry { type symmetryPlane; } defaultFaces { type zeroGradient; } } |
July 5, 2016, 23:06 |
#26 |
Baris (Heewa)
Rep Power: 13 |
Hi Henry,
Most probably your T value is going to negative or extremely high. To see in into T.Eqn file add Info << T.min() << " " << T.min() <<endl; then you can understand reason. hope it helps you. Baris |
July 6, 2016, 15:54 |
#27 |
Henry
Rep Power: 10 |
It looks like that was the problem, but I'm lost as to how to go about solving it. What can I do to prevent T from going out of control like that?
July 13, 2016, 15:52 |
#28 |
Moritz
Rep Power: 10 |
Hey together,
could anyone please explain me how I can compile the thermo files if I want for example some output debugging in the thermoI.H file??? I somehow don't understand where these files are included in any Make/files... Any help would be sincerely appreciated Thanks and cheers moritz |
July 13, 2016, 16:50 |
#29 |
Henry
Rep Power: 10 |
go to the directory that includes the thermoI.H file, and once you edit whatever debugging code you want into that file, type "wclean" and then "wcompile", which should recompile all the files in that directory for you
July 14, 2016, 04:26 |
#30 |
Moritz
Rep Power: 10 |
Hi henry,
I didnt want to do it as root but I guess it is easier. But still it's not giving me the info in my logfile I acutally wrote in the code. Why? Code:
template<class Thermo, template<class> class Type> inline Foam::scalar Foam::species::thermo<Thermo, Type>::T ( scalar f, scalar p, scalar T0, scalar (thermo<Thermo, Type>::*F)(const scalar, const scalar) const, scalar (thermo<Thermo, Type>::*dFdT)(const scalar, const scalar) const, scalar (thermo<Thermo, Type>::*limit)(const scalar) const ) const { scalar Test = T0; scalar Tnew = T0; scalar Ttol = T0*tol_; int iter = 0; Info<< "Test = " << Test << endl; Info<< " f = " << f << endl; do { Test = Tnew; Tnew = (this->*limit) (Test - ((this->*F)(p, Test) - f)/(this->*dFdT)(p, Test)); scalar Thilf = mag(Tnew - Test); Info<< "DeltaT = " << Thilf << endl; if (iter++ > maxIter_) { FatalErrorIn ( "thermo<Thermo, Type>::T(scalar f, scalar T0, " "scalar (thermo<Thermo, Type>::*F)" "(const scalar) const, " "scalar (thermo<Thermo, Type>::*dFdT)" "(const scalar) const, " "scalar (thermo<Thermo, Type>::*limit)" "(const scalar) const" ") const" ) << "Maximum number of iterations exceeded" << abort(FatalError); } } while (mag(Tnew - Test) > Ttol); return Tnew; } |
July 14, 2016, 05:10 |
#31 |
Moritz
Rep Power: 10 |
Ok, sorry for the stupid question. You have to compile the whole thermophysical folder if anyone faces the same problem at some point.
Thanks anyway guys! |
July 21, 2016, 17:44 |
chtMultiRegionSimpleFoam - Solution suggestion
#32 |
Peter Hess
Rep Power: 17 |
Hello Everybody,
Increasing the Mesh quality by increasing the number of cells solved my divergence problem and no error massage appeared anymore. - My mesh is created by blockMesh - chtMultiRegionSimpleFoam has been used as a test - I left the maximum iterations by 100 (did not followed the suggestion above) - in my test I gave: runTimeModifiable false I hope it can helps Regards Peter |
July 25, 2016, 09:33 |
#33 |
Moritz
Rep Power: 10 |
Dear foamer,
I solved the problem. In my case, the error occurred because of different values for T_common in the therm.dat file. Make sure that all reactants involved in the chemical reactions have the same value for T_common. But I think in the current version this bug is already fixed. Cheers |
September 6, 2016, 05:02 |
#34 | |
Junqian CAI
Rep Power: 10 |
October 12, 2016, 09:12 |
Resolved
#35 |
Vijaya Kumar. G
Rep Power: 10 |
1) Reduce delta T to a order 10000 times lower than the current value.
2) Set Max Courant Number to 1 3) Set ´adjustTimeStep´ to yes try running the solver again, if it crashes yet again, reduce the delta T even lower then try running again. This worked for me. The problem was with higher courant number and that leading to a diverged solution. |
March 29, 2017, 07:19 |
#36 | |
Hrushikesh Khadamkar
Rep Power: 16 |
We are also struggling with this issue of temperature update using N-R method. Can you share your brent method code implemented in thermoI.H file? We also feel that by using Brent method, this problem can be solved. Hrushilesh |
March 31, 2017, 17:42 |
#37 |
Andrea Matiz C
Rep Power: 9 |
hi
Did you find a solution to your problem? I'm having the same problem with the compressible solver rhoSimpleFoam. Thanks in advance! |
April 3, 2017, 14:47 |
#38 |
Andrea Matiz C
Rep Power: 9 |
Hi
I'm having the same ṕroblem you mentioned. Did you manage to solve it? what did you do? Thanks in advance Andrea |
April 5, 2017, 09:53 |
#39 | |
amin jalalian
Rep Power: 12 |
Hi srahul I have some questions, How can make the thermoI.H file? Can you send brent solver text in openFoam? thanks |
May 15, 2017, 05:45 |
My mistake was...
#40 |
Peter Hess
Rep Power: 17 |
Hello Everybody!
chtMultiRegionSimpleFoam has been used here! I faced the problem also like many of you. I tried almost everything has been written here without a success... I increased the number of cells to a very high number (1 000 000) cells for 100 x 100 x 100 mm region(s). That worked, but the results where very strange. And I found the mistake I made! I made the folowing: - 3D Design FreeCAD then export as stl - Used blockMesh to make my initial mesh - In openFoam using snappyMesh to build my final mesh The dimensions in my stl file were in mm. That means FreeCAD exports the 100... snappyMesh read this 100 as 100 m instead of the 100 mm exported My blockMesh mesh is also too big made (factor 1000)... Reducing the dimensions in factor 1000 bei: convertToMeters 0.001 in blockMeshDict AND in my exported stl file (FreeCAD) Solved my problem! Check up the dimensions (in your blockMeshDict as example) is my suggestion here. Regards Peter Last edited by peterhess; May 15, 2017 at 15:45. |
maximum number of iterations | solomon | FLUENT | 7 | April 25, 2024 02:27 |
Maximum number of iterations exceeded | liugx212 | OpenFOAM Running, Solving & CFD | 3 | August 28, 2013 08:09 |
FOAM FATAL IO ERROR | msrinath80 | OpenFOAM Running, Solving & CFD | 4 | July 30, 2008 10:06 |
Internal Error: Number of tree levels exceeded | ahlo | CFX | 0 | March 4, 2008 13:45 |
FOAM FATAL ERROR | derath | OpenFOAM Pre-Processing | 1 | June 10, 2006 14:20 |
