Pitz Daily Test Case temperature measurements
Old   May 8, 2006, 11:09
Default Dear all, I am interested i
Daniele Panara
panara is on a distinguished road
Dear all,
I am interested in the Pitz Daily test case. And in particular in temperature profiles.
I have noticed that in the paper of Weller et al. (27th Symposium on Combustion,1998, pg 899-907) the numerical temperature profiles are compared with experimental data from Pitz and Daily (AIAA Journal 21-11,1983 pg 1565-1570), but in the above mentioned article I could not find any temperature measurements.
Do temperature measurements for the Pitz Daily case exist? if yes what is the right reference?
Thanks in advance,
Daniele
panara is offline   Reply With Quote
Old   May 9, 2006, 14:16
Default I am also interested in the Pi
cfdfans
I am also interested in the PitzDaily case.
I run the Xoodles\pitzDaily3D, use the default 'combustionProperties' value.
and run Xoodles\pitzDaily, set 'ignite' is 'yes',but the two cases do not ignite and combustion. when I increase the value of 'strength' of 'ignitionSites' to 200, the cases ignite,but reach error soon,
"attempt to use janafThermo<equationofstate> out of temperature range 200 -> 5000; T = 192.877 "
I wonder how to run the cases pitzDaily3D and pitzDaily with combustion? what are the meaning of the following Properties? when 'strength' is '2', means how high temperature? and what is the 'ignitionSphereFraction' , 'ignitionThickness' and 'ignitionKernelArea' ?
thanks !
qf
ignitionSites
location (0 0 0);
diameter 0.003;
start 0;
duration 0.001;
strength 2;
ignitionSphereFraction 1;
ignitionThickness ignitionThickness [0 1 0 0 0 0 0] 0;
ignitionCircleFraction 0;
ignitionKernelArea ignitionKernelArea [0 2 0 0 0 0 0] 0;
Old   March 22, 2007, 04:00
Default Any News here ?
O R
arkangel is on a distinguished road
Any News here ?
arkangel is offline   Reply With Quote
3d test case Hassan Raiesi Main CFD Forum 1 August 19, 2006 13:33
Test Case ganesh Main CFD Forum 0 March 16, 2006 13:34
Looking for test case William M. Main CFD Forum 2 May 26, 2005 04:45
test case? lsm Main CFD Forum 0 June 14, 2004 12:39
test case Follet Main CFD Forum 0 July 8, 2002 05:07
