January 2, 2007, 13:10 |
For a large case (approx 11 mi
Srinath Madhavan (a.k.a pUl|)
Rep Power: 21 |
For a large case (approx 11 million cells) is it normal to expect the sample utility to take over 6 hours just to get some velocity values along a line?
Oh, and it's still not done af
Rep Power: 21 |
Oh, and it's still not done after 6 hours.
January 2, 2007, 13:38 |
Seems bit excessive.
- Chec
Mattijs Janssens
Rep Power: 26 |
- Check that your line is not along an edge or face of the mesh. This might cause tracking to fail. - See if using a 'cloud' sampleSet instead of 'uniform' works. Cloud in your sampleDict takes a pointField: cloud { points ((x y z) .. (x y z)) } Either way I'd be interested in what the outcome is. |
January 3, 2007, 04:12 |
I have experienced s
Hannes Kröger
Rep Power: 18 |
I have experienced similar problems with the sample utility. The utility starts, the mesh is created and then it hangs. When I kill it using Ctrl-C, the following stack trace is output: /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.3 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : sample .. F2LES_ini2 -latestTime Date : Jan 03 2007 Time : 08:48:02 Host : palamedes.fms.uni-rostock.de PID : 12428 Root : .. Case : F2LES_ini2 Nprocs : 1 Create time Create mesh for time = 1.01555 Time = 1.01555 Foam::error::printStack(Foam:stream&) Foam::sigInt::sigIntHandler(int) /lib64/libc.so.6 [0x39fea30210] Foam::particle<foam::passiveparticle>::findFaces(F oam::Vector<double> const&) Foam::particle<foam::passiveparticle>::trackToFace (Foam::Vector<double> const&, double&, bool) sample [0x465596] sample [0x466288] sample [0x466c23] sample [0x467751] Foam::sampleSet::addwordConstructorToTable<foam::u niformset>::New(Foam::polyMesh const&, Foam::meshSearch&, Foam::dictionary const&) sample [0x45cde7] sample [0x43e854] sample [0x41ad4c] __libc_start_main __gxx_personality_v0 It seems to get stuck in some kind of search procedure (Foam::particle<foam::passiveparticle>::findFaces) . The problem first occured on a large case (16 Mio cells) but today also with a smaller one (500k cells). Furthermore, the problem occurs only on 64bit machines. On 32bit computers, sample is working with the small case. (I could not try the large one, since we have only 64bit computers with enough memory for the 16 Mio case) Regards, Hannes
silentdynamics GmbH - http://silentdynamics.de open source CAE software solutions & support |
January 3, 2007, 16:46 |
This sounds as if your samplin
Mattijs Janssens
Rep Power: 26 |
This sounds as if your sampling line is along a face. Just offset it a bit or do the cloud suggestion above and please let me know the outcome.
January 3, 2007, 21:11 |
Apologies for the delayed repl
Rep Power: 21 |
Apologies for the delayed reply Mattijs. Your cloud suggestion worked without any problems. It appears that the sample utility does not like my wall boundary located at y = 0.02 even when using cloud. Instead y = 0.0199999999 works. And yes, it took only 4 odd minutes now. The uniform option is however still not happy with y = 0.0199999999.
Thanks very much for your help Mattijs! |
January 4, 2007, 05:05 |
Move your sampling points a bi
Mattijs Janssens
Rep Power: 26 |
Move your sampling points a bit more. Having y=0.0199999999 still sounds as if you've perturbed it by only a tiny amount. Think e.g. 0.1% of cell dimension.
April 10, 2007, 22:35 |
Is there a way to sample data
Hans-Hermann Jonas
Is there a way to sample data from moving walls?
I am working on fluid-structure interactions and I would like to plot the pressure distribution of an elastically-mounted cylinder (free moving in y direction with damping and spring). From the stationary cylinder case I use the sample utility with a cloud of points on the body surface but that does not work any more when the body is moving freely. So I am looking for sample boundary patches or dumping it directly into a log-file (so fare I have not managed to write the pressure of the body patch). |
April 11, 2007, 02:27 |
Would writing all the face pre
#9 |
Hrvoje Jasak
Rep Power: 33 |
Would writing all the face pressures from the moving patch be an option? The thing is that in a moving patch it is not easy to grab anything geometrically - because the patch is moving :-)
If you'd like the data from your patch, you can do something like (I am looking for a patch called "piston"): label pistonPatchID = mesh.boundaryMesh().findPatchID("piston"); if (pistonPatchID > -1) { Info << "face values" << p.boundaryField()[pistonPatchID] << endl; else { Info << "Error: patch not found" << endl; } } Hope you can follow this, Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
April 11, 2007, 18:25 |
Alternatively you could try th
#10 |
Mattijs Janssens
Rep Power: 26 |
Alternatively you could try the sampleSurface utility with constantPatch or interpolatedPatch. (see the sample dictionary in $FOAM_UTILITIES/postProcessing/miscellaneous/sampleSurface)
It should be able to handle moving meshes (not really tested though) |
April 30, 2009, 10:32 |
Problem sampling UPrime2Mean
#11 |
Leonardo Giampani Morita
Rep Power: 17 |
In order not to create a new thread, I decided to ask for your help in this one, even though it's quite old... My problem is the following: after having run the channelOodles tutorial, I'm trying to post-process it using the sample utility. Almost everything works fine until now, except the probe of UPrime2Mean...I receive the following error message: m::error:rintStack(Foam::Ostream&) in "/model/giampani/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigSegv::sigSegvHandler(int) in "/model/giampani/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" #2 ?? in "/lib64/libc.so.6" #3 Foam::writer<Foam::SymmTensor<double> >::New(Foam::word const&) in "/model/giampani/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libsampling.so" #4 void Foam::sampledSets::sampleAndWrite<Foam::SymmTensor <double> >(Foam::sampledSets::fieldGroup<Foam::SymmTensor<d ouble> >&) in "/model/giampani/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libsampling.so" #5 Foam::sampledSets::write() in "/model/giampani/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libsampling.so" #6 Foam::sampledSurfaces::read(Foam::dictionary const&) in "/model/giampani/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/sample" #7 __libc_start_main in "/lib64/libc.so.6" #8 Foam::regIOobject::write() const in "/model/giampani/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/sample" Incident de segmentation Does anybody know what the cause of the problem may be? Thank you. Regards, Leonardo |
May 12, 2009, 12:08 |
#12 |
Rep Power: 17 |
Any suggestion?
December 21, 2012, 06:51 |
#13 | |
Chen Yang
Rep Power: 14 |
Leonardo, I met the same problem. Have you solved it?
OF15x sample utility does not accept component | elisabet | OpenFOAM Bugs | 2 | February 18, 2009 12:58 |
[Commercial meshers] Several problems with the mesh conversion utility when converting the meshes from Gridgen | su_junwei | OpenFOAM Meshing & Mesh Conversion | 2 | July 27, 2008 00:58 |
Sample utility problem in OpenFOAM141dev | 7islands | OpenFOAM Bugs | 1 | January 4, 2008 09:34 |
Sample has problems with baffles propably problem with particletrackToFace | mattijs | OpenFOAM Bugs | 1 | October 22, 2007 10:20 |
Problem with sample utility | roberthino | OpenFOAM Post-Processing | 6 | August 23, 2007 16:29 |
