Gradients on surfaces or how to find neighbour faces for face on a patch
Old   November 27, 2009, 12:06
Default lduSolver compiling error
  #21
sunny
sunny01 is on a distinguished road
Hi Andrea,
I am facing exactly the same problem as you are. Have you been able to sort it out yet - seems no one has replied to your post.
Please kindly advise me what to do if you have fixed the problem. I get exactly the same error message as you reported when I try to compile lduSolver:
error: expected class-name before "{" token
Otherwise I will be glad if anyone knows the solution to this problem and is able to help.
Thanks for your anticipated reply.
Sunny
sunny01 is offline   Reply With Quote
Old   May 25, 2010, 08:08
Johan Nilsson
jnilsson is on a distinguished road
Hi!
I'm also intrested in calculating the tangential surface gradient as in the example is said to do, however the links do no longer work. If anyone would like to share it with me once again it could help me a lot.
Thank you in advance.
/ Johan
Originally Posted by tehache View Post
Hi Normunds,
I suppose its o.k. if I post it here again, since Zeljko tried to do that already.
So here is what he tried to post and then sent me by mail:
http://servww6.ww.uni-erlangen.de/~jung/surfGradCase.tgz
http://servww6.ww.uni-erlangen.de/~jung/surfaceGradientFoam.tgz
Originally Posted by ztukovic View Post
Tangential gradient can be calculated using finite are calculus. See the attached application and case.
Regards,
Zeljko Tukovic
jnilsson is offline   Reply With Quote
How to access to faces of a patch jaswi OpenFOAM Running, Solving & CFD 17 October 7, 2020 11:30
Frontal projected reference face area computation from patch kprzysowagmailcom OpenFOAM Pre-Processing 0 January 6, 2009 11:06
Intersection from ray witrh patch or face hjasak OpenFOAM Running, Solving & CFD 1 August 1, 2007 11:02
Patch face centres order shrina OpenFOAM Running, Solving & CFD 1 October 3, 2006 04:48
Reversed flow in ###faces on face ### TOM FLUENT 1 March 1, 2002 12:43
