InteFoam Tolerances
Old   May 10, 2007, 05:22
Default Hi, I use interFoam to simu
marcelo
I use interFoam to simulate bubbles in glycerine, I obtained bad results, and I don't know what is the numerical problem. With water there aren't problems.
I use this
solvers
pcorr ICCG 1e-10 0;
pd ICCG 1e-10 0;
gamma BICCG 1e-12 0;
U BICCG 1e-08 0;
PISO
momentumPredictor yes;
nCorrectors 3;
nNonOrthogonalCorrectors 0;
nGammaCorr 1;
nGammaSubCycles 4;
cGamma 2;
Regards
Old   May 10, 2007, 05:30
Default Is it only the density and vis
Joakim Möller
joakim is on a distinguished road
Is it only the density and viscosity that differs between water and glycerine?
Did u try changing one thing at a time to find out what made the changes?
Regards
/Joakim
joakim is offline   Reply With Quote
Old   May 10, 2007, 15:16
Default only the viscosity is the impo
marcelo
only the viscosity is the important change; for water is 0.001 and for glycerine is 1.045, (density: water 1000, glycerine 1257; and surface tension: water 0.07, glycerine 0.063)
Regards
Old   May 12, 2007, 21:02
Default OK, sorry I do not have any id
Joakim Möller
OK, sorry I do not have any idea for the moment.
I have a question though. Did you initialize with a spherical bubble. If so how did you accomplish the initialization?
Regards
/Joakim
Old   May 15, 2007, 21:52
Default the initial condition is this
marcelo
no the first buble
InteFoam Tolerances marcelo OpenFOAM Running, Solving & CFD 1 May 25, 2007 04:46
