June 12, 2007, 07:54 |
Dear All,
I'm trying to get
Gavin Tabor
Rep Power: 17 |
Dear All,
I'm trying to get my head around something here. I've been running (with a student) LES calculations on 12 processors in parallel. Used decomposePar to split the mesh giving processors 0 - 11, and have successfully run the simulation. So far, so good. We also wanted to sample the data at specific points (9 points in all) along the geometry to evaluate energy spectra etc. Established a probleLocations dictionary in constant before doing the decomposition. For a normal (single processor) run, this generates a probes directory containing probe data in files (split up according to timestep). For the parallel run, we appear to have probes directories in 4 of the 12 processor directories; each probe directory contains files each of which appears to contain data for all 9 probe locations. However the data is different from each processor (not much, but significantly - 4th sig fig in most cases). I'm trying to understand what is happening here? Which probes directory should we be looking at? We are (for complicated reasons) still running 1.1, so this might be a "feature" which has been resolved in later versions. Any suggestions? Gavin |
June 12, 2007, 14:59 |
Each probes/ directory will on
Mattijs Janssens
Rep Power: 26 |
Each probes/ directory will only give the probes which are on the local processor.
(and if none of the probes are on the local processor it will write no probes/ directory) In 1.4 the probes are properly collected onto the master processor. |
Probes in OpenFOAM14 | otsuki | OpenFOAM Running, Solving & CFD | 2 | May 16, 2007 07:18 |
Probes | msrinath80 | OpenFOAM Pre-Processing | 4 | April 28, 2006 07:55 |
Running MPI code on a multiprocessor node | wen | Main CFD Forum | 7 | April 19, 2006 17:35 |
Multiprocessor solving, IPREC | M. Derksen | CFX | 0 | November 30, 1999 15:16 |
