Dimension of mesh
Old   June 19, 2007, 05:24
Default Hi All, when i read in a mesh
jackdaniels83 is on a distinguished road
Hi All,
when i read in a mesh (in my case from gmsh) that is written in millimeters, do i have to scale it by factor 1/1000 in foam to get the right values for U? And how is the surface flow in ParaView written? m³/sec, liter/sec, liter/min or something like that?
I hope one can help me,
Daniel
jackdaniels83 is offline   Reply With Quote
Old   June 19, 2007, 05:31
Default Everything inside OpenFOAM is
Francesco Del Citto
fra76 is on a distinguished road
Everything inside OpenFOAM is treated in meters, kg, seconds, etc...
So, yes, you have to scale the mesh, if it has been generated in millimiters.
The surface flow in ParaView should match the units used inside OF, so I guess it is m³/sec
Francesco
fra76 is offline   Reply With Quote
Old   June 19, 2007, 05:52
Default Thanks Francesco, that's exac
Thanks Francesco,
that's exactly what i needed to know. Can someone confirm that ParaView is also using the SI units?
Daniel
Old   June 19, 2007, 07:21
Default ParaView is just a postprocess
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
ParaView is just a postprocessor, so it doesn't care about units.
This means it will preserve whatever values it receives.
Dragos
dmoroian is offline   Reply With Quote
Dimension rengu OpenFOAM Running, Solving & CFD 1 October 30, 2007 05:29
DES/LES and the 3rd Dimension Bob Main CFD Forum 1 August 3, 2004 10:55
mesh dimension marco di vice Main CFD Forum 1 October 23, 2001 20:57
1D dimension eddy Main CFD Forum 7 September 3, 2000 08:24
