SimpleFoam boundary conditions changed in OF 14
Old   May 13, 2007, 11:34
Default Hello, I've got this error
Ervin Adorean
adorean is on a distinguished road
I've got this error in OF 1.4 - simpleFoam with a case setup that worked in OF 1.3:
--> FOAM FATAL IO ERROR : keyword U is undefined in dictionary "/home/ervin/OpenFOAM/ervin-1.4/tutorials/simpleFoam/intake-4mm/0/p::p-out"
file: /home/ervin/OpenFOAM/ervin-1.4/tutorials/simpleFoam/intake-4mm/0/p::p-out from line 41 to line 43.
From function dictionary::lookupEntry(const word& keyword) const
in file db/dictionary/dictionary.C at line 146.
FOAM exiting
My 0/p dictionary:
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.3 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
FoamFile
version 2.0;
format ascii;
root "";
case "";
instance "";
local "";
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 101325;
boundaryField
p-in
type totalPressure;
p0 uniform 102125;
value uniform 102125;
p-out
type totalPressure;
p0 uniform 98205;
value uniform 98205;
wall
type zeroGradient;
Can someone tell why it is asking for U, then phi, rho, gamma ... in the 0/p file?
Thank you,
Ervin
adorean is offline   Reply With Quote
Old   May 15, 2007, 01:17
Default Hello again, Has anyone had
Ervin Adorean
Hello again,
Has anyone had this problem with OF 1.4 and simpleFoam - with this B.C.?
I don't understand why is it complaining about those entries in that file (0/p).
I repeat: the exactly same setup worked just fine in OF 1.3.
Anyone?
Thanks,
Ervin
Old   May 26, 2007, 11:46
Default Didn't anybody observe the abo
Ervin Adorean
Didn't anybody observe the above described behaviour of simpleFoam and rhoSimpleFoam (for those kind of B.C.)?
What changed from 1.3 to 1.4?
Am I making a mistake with the B.C. in OF 1.4?
Old   May 26, 2007, 13:38
Default Sorry for the wasted space. Pr
Ervin Adorean
Sorry for the wasted space. Problem solved.
Old   June 22, 2007, 08:17
Default Hello Ervin, Could you expl
Guido Adriaensen
guido_adriaensen is on a distinguished road
Hello Ervin,
Could you explain how you solved the problem? Thank you.
Guido
guido_adriaensen is offline   Reply With Quote
Old   June 22, 2007, 08:50
Default Hello, By using this for th
Ervin Adorean
By using this for the p file:
FoamFile
version 2.0;
format ascii;
root "";
case "";
instance "";
local "";
object p;
dimensions [1 -1 -2 0 0 0 0];
boundaryField
p-in
type totalPressure;
p0 uniform 102125;
U U;
phi phi;
rho rho;
psi none;
gamma 1.4;
p-out
type totalPressure;
p0 uniform 98205;
U U;
phi phi;
rho rho;
psi none;
gamma 1.4;
wall
type zeroGradient;
Ervin
Define non uniform TKE boundary condition in simpleFOAM qtian OpenFOAM Running, Solving & CFD 9 July 30, 2007 15:54
Rotating boundary simplefoam gabriel OpenFOAM Running, Solving & CFD 4 June 4, 2007 04:41
SimpleFoam boundary conditions hani OpenFOAM Running, Solving & CFD 2 January 10, 2007 03:44
Integral boundary conditions turbulent intensitylength boundary conditions olesen OpenFOAM Running, Solving & CFD 0 July 27, 2006 08:18
Problem about water decreased and boundary changed Luke FLUENT 2 June 6, 2006 15:54
