May 29, 2007, 04:35 |
When I recompile OpenFOAM 1.4
Srinath Madhavan (a.k.a pUl|)
Rep Power: 21 |
When I recompile OpenFOAM 1.4 and run decomposePar, I get the following warnings. I have defined probe points in controlDict.
Can I ignore these warnings: [madhavan@head02 icoFoam]$ decomposePar . cavity_parallel /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.4 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : decomposePar . cavity_parallel Date : May 29 2007 Time : 01:33:05 Host : head02.cein.ualberta.ca PID : 17797 Root : /amd/cein/homes/1/d/madhavan/OpenFOAM/madhavan-1.4/run/tutorials/icoFoam Case : cavity_parallel Nprocs : 1 Create time Selecting function probes Time = 0 Create mesh Calculating distribution of cells Selecting decompositionMethod metis Finished decomposition in 0 s Calculating original mesh data Distributing cells to processors Distributing faces to processors Calculating processor boundary addressing Distributing points to processors Constructing processor meshes Selecting function probes --> FOAM Warning : From function dlLibraryTable::open(const dictionary& dict, const word& libsEntry, const TablePtr tablePtr) in file lnInclude/dlLibraryTableTemplates.C at line 67 library "libsampling.so" did not introduce any new entries Processor 0 Number of cells = 199 Number of faces shared with processor 1 = 24 Number of processor patches = 1 Number of processor faces = 24 Number of boundary faces = 438 Selecting function probes --> FOAM Warning : From function dlLibraryTable::open(const dictionary& dict, const word& libsEntry, const TablePtr tablePtr) in file lnInclude/dlLibraryTableTemplates.C at line 67 library "libsampling.so" did not introduce any new entries Processor 1 Number of cells = 201 Number of faces shared with processor 0 = 24 Number of processor patches = 1 Number of processor faces = 24 Number of boundary faces = 442 Number of processor faces = 24 Max number of processor patches = 1 Max number of faces between processors = 24 Processor 0: field transfer Selecting function probes --> FOAM Warning : From function dlLibraryTable::open(const dictionary& dict, const word& libsEntry, const TablePtr tablePtr) in file lnInclude/dlLibraryTableTemplates.C at line 67 library "libsampling.so" did not introduce any new entries Processor 1: field transfer Selecting function probes --> FOAM Warning : From function dlLibraryTable::open(const dictionary& dict, const word& libsEntry, const TablePtr tablePtr) in file lnInclude/dlLibraryTableTemplates.C at line 67 library "libsampling.so" did not introduce any new entries End. [madhavan@head02 icoFoam]$ |
May 30, 2007, 01:52 |
This appears to be a bug in th
Rep Power: 21 |
This appears to be a bug in the OpenFOAM downloaded from Sourceforge (64 bit version). When you have probes defined in controldict and you try to decompose a case, you get these warnings. Also, after the parallel simulation, one is unable to launch paraFoam. Perhaps this is a bug that was overlooked. Can someone confirm please?
May 30, 2007, 04:40 |
I've got the same message befo
Nicolas Coste
Rep Power: 17 |
I've got the same message before running the case.
In my case probes directory is created but there is nothing inside. Concerning parafoam I'm not sure because I'm using Visit, but you must remove the probes function in the controlDict file. |
May 30, 2007, 04:52 |
I will post this again on Open
Rep Power: 21 |
I will post this again on OpenFOAM-Bugs forum. Maybe Henry can look at it. Thanks for confirming my observation.
July 3, 2007, 11:00 |
Hi
When i run serial case
abhishek k n
Rep Power: 17 |
Hi
When i run serial case it does not give any error. But i get error with parallel as [5] #0 Foam::error::printStack(Foam:stream&)[6] #0 Foam::error::printStack(Foam:stream&) [5] #1 Foam::sigFpe::sigFpeHandler(int) [6] #1 Foam::sigFpe::sigFpeHandler(int) [5] #2 [6] #2 [4] #0 Foam::error::printStack(Foam:stream&)__restore_rt__restore_rt [5] #3 void Foam::processorLduInterface::compressedSend<double >(Foam::UList<double> const&, bool) const [6] #3 void Foam::processorLduInterface::compressedSend<double >(Foam::UList<double> const&, bool) const [4] #1 Foam::sigFpe::sigFpeHandler(int) [6] #4 Foam::processorFvPatchField<foam::vector<double> >::initInterfaceMatrixUpdate(Foam::Field<double> const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, unsigned char, bool) const [5] #4 Foam::processorFvPatchField<foam::vector<double> >::initInterfaceMatrixUpdate(Foam::Field<double> const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, unsigned char, bool) const [4] #2 __restore_rt [4] #3 void Foam::processorLduInterface::compressedSend<double >(Foam::UList<double> const&, bool) const [5] #5 Foam::lduMatrix::initMatrixInterfaces(Foam::FieldF ield<foam::field,> const&, Foam::UPtrList<foam::lduinterfacefield> const&, Foam::Field<double> const&, Foam::Field<double>&, unsigned char) const [6] #5 Foam::lduMatrix::initMatrixInterfaces(Foam::FieldF ield<foam::field,> const&, Foam::UPtrList<foam::lduinterfacefield> const&, Foam::Field<double> const&, Foam::Field<double>&, unsigned char) const [6] #6 Foam::lduMatrix::Tmul(Foam::Field<double>&, Foam::tmp<foam::field<double> > const&, Foam::FieldField<foam::field,> const&, Foam::UPtrList<foam::lduinterfacefield> const&, unsigned char) const [5] #6 Foam::lduMatrix::Tmul(Foam::Field<double>&, Foam::tmp<foam::field<double> > const&, Foam::FieldField<foam::field,> const&, Foam::UPtrList<foam::lduinterfacefield> const&, unsigned char) const [6] #7 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const [5] #7 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const [4] #4 Foam::processorFvPatchField<foam::vector<double> >::initInterfaceMatrixUpdate(Foam::Field<double> const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, unsigned char, bool) const [6] #8 [5] #8 [4] #5 Foam::lduMatrix::initMatrixInterfaces(Foam::FieldF ield<foam::field,> const&, Foam::UPtrList<foam::lduinterfacefield> const&, Foam::Field<double> const&, Foam::Field<double>&, unsigned char) const [4] #6 Foam::lduMatrix::Tmul(Foam::Field<double>&, Foam::tmp<foam::field<double> > const&, Foam::FieldField<foam::field,> const&, Foam::UPtrList<foam::lduinterfacefield> const&, unsigned char) constFoam::fvMatrix<foam::vector<double> >::solve(Foam::Istream&)Foam::fvMatrix<foam::vecto r<double> >::solve(Foam::Istream&) [4] #7 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const [6] #9 [5] #9 [4] #8 Foam::lduMatrix::solverPerformance Foam::solve<foam::vector<double> >(Foam::tmp<foam::fvmatrix<foam::vector<double> > > const&)Foam::lduMatrix::solverPerformance Foam::solve<foam::vector<double> >(Foam::tmp<foam::fvmatrix<foam::vector<double> > > const&)Foam::fvMatrix<foam::vector<double> >::solve(Foam::Istream&) [4] #9 [6] #10 [5] #10 Foam::lduMatrix::solverPerformance Foam::solve<foam::vector<double> >(Foam::tmp<foam::fvmatrix<foam::vector<double> > > const&)mainmain [4] #10 main [6] #11 __libc_start_main [5] #11 __libc_start_main [4] #11 __libc_start_main [6] #12 __gxx_personality_v0 [4] #12 __gxx_personality_v0 [5] #12 __gxx_personality_v0 at ../sysdeps/x86_64/elf/start.S:116 ----------------------------------------------------------------------------- One of the processes started by mpirun has exited with a nonzero exit code. This typically indicates that the process finished in error. If your process did not finish in error, be sure to include a "return 0" or "exit(0)" in your C code before exiting the application. PID 7314 failed on node n2 (172.28.0.125) due to signal 8. ----------------------------------------------------------------------------- |
July 3, 2007, 12:39 |
How exactly are you running th
Rep Power: 21 |
How exactly are you running the parallel simulation? Is this stock OF 1.4 or did you build from source?
July 3, 2007, 12:44 |
Hi
Sorry i could not under
abhishek k n
Rep Power: 17 |
Hi
Sorry i could not understand your question stock OF 1.4 or did you build from source? |
July 4, 2007, 03:08 |
Stock OpenFOAM 1.4 refers to t
Rep Power: 21 |
Stock OpenFOAM 1.4 refers to the precompiled version distributed by OpenCFD.
July 4, 2007, 05:10 |
Hi
I used the pre compiled
#9 |
abhishek k n
Rep Power: 17 |
Hi
I used the pre compiled version of OpenFOAM 1.4 |
July 4, 2007, 08:25 |
Ahem, OK. What about the envir
#10 |
Rep Power: 21 |
Ahem, OK. What about the environment variable WM_64. Did you set it to on? Can you also post the exact sequence of commands you used to start the parallel version. Also is this SMP hardware or distributed node with interconnect?
July 4, 2007, 09:40 |
hi
Surprisingly i ran it a
#11 |
abhishek k n
Rep Power: 17 |
hi
Surprisingly i ran it again it is working now. First time it stopped after 35 seconds and but now it has reached 108 seconds without any problem. One more surprise, WM_64 was not 'on' but still it choose a 64 bit version. I use Lamboot and mpi type to run the parallel. It is a distributed node with interconnect. |
July 4, 2007, 10:18 |
I faced a similar problem a wh
#12 |
Rep Power: 21 |
I faced a similar problem a while ago. Check this[1] post to see the mpirun command syntax that solved the issue.
[1] http://www.cfd-online.com/OpenFOAM_D...tml?1154110876 |
July 4, 2007, 12:24 |
Hi
Case description
Mesh
#13 |
abhishek k n
Rep Power: 17 |
Hi
Case description Mesh Size: 1.2 Million Time step: 0.01 Under relaxation: 0.1 Standard k-e model Upwind schemes for divergence term Non-orthogonal corrector: 10 Imported from starCCM ++, the checkmesh reported some highly skewed, Non-orthogonal cells. Still i ran the case, the relevant changes for mpirun is made as suggested by you. Still i get this error. What could be the mistake the mesh or the way mpi command is used If it has to do with mesh then any cleaning tool available in OF or get the mesh corrected in STAR Time = 0.09 DILUPBiCG: Solving for Ux, Initial residual = 0.0629195, Final residual = 4.30642e-11, No Iterations 3 DILUPBiCG: Solving for Uy, Initial residual = 0.0580816, Final residual = 6.80881e-11, No Iterations 3 DILUPBiCG: Solving for Uz, Initial residual = 0.0694269, Final residual = 1.07529e-10, No Iterations 3 DICPCG: Solving for p, Initial residual = 0.597653, Final residual = 9.51117e-09, No Iterations 262 DICPCG: Solving for p, Initial residual = 0.149701, Final residual = 9.49542e-09, No Iterations 250 DICPCG: Solving for p, Initial residual = 0.0316422, Final residual = 9.67963e-09, No Iterations 237 DICPCG: Solving for p, Initial residual = 0.00462459, Final residual = 8.81629e-09, No Iterations 208 DICPCG: Solving for p, Initial residual = 0.000570972, Final residual = 9.57096e-09, No Iterations 184 DICPCG: Solving for p, Initial residual = 8.75491e-05, Final residual = 9.31579e-09, No Iterations 160 DICPCG: Solving for p, Initial residual = 2.12035e-05, Final residual = 9.92397e-09, No Iterations 63 DICPCG: Solving for p, Initial residual = 7.77277e-06, Final residual = 9.97595e-09, No Iterations 29 DICPCG: Solving for p, Initial residual = 4.64155e-06, Final residual = 9.72118e-09, No Iterations 15 DICPCG: Solving for p, Initial residual = 2.84015e-06, Final residual = 9.60676e-09, No Iterations 15 DICPCG: Solving for p, Initial residual = 1.965e-06, Final residual = 9.74522e-09, No Iterations 10 DICPCG: Solving for p, Initial residual = 1.38749e-06, Final residual = 9.83813e-09, No Iterations 9 DICPCG: Solving for p, Initial residual = 1.07198e-06, Final residual = 8.83078e-09, No Iterations 9 DICPCG: Solving for p, Initial residual = 8.83087e-07, Final residual = 9.97312e-09, No Iterations 6 DICPCG: Solving for p, Initial residual = 7.93485e-07, Final residual = 9.5128e-09, No Iterations 8 DICPCG: Solving for p, Initial residual = 7.67152e-07, Final residual = 9.17566e-09, No Iterations 7 time step continuity errors : sum local = 2605.87, global = 172.42, cumulative = 172.42 DILUPBiCG: Solving for epsilon, Initial residual = 0.999997, Final residual = 4.04242e-09, No Iterations 3 bounding epsilon, min: 0.0156719 max: 6.08811e+19 average: 3.20073e+14 DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 1.50261e-09, No Iterations 3 ExecutionTime = 256.63 s ClockTime = 732 s Time = 0.1 [6] #0 Foam::error::printStack(Foam:stream&) [6] #1 Foam::sigFpe::sigFpeHandler(int) [6] #2 __restore_rt [6] #3 void Foam::processorLduInterface::compressedSend<foam:: vector<double> >(Foam::UList<foam::vector<double> > const&, bool) const [6] #4 Foam::processorFvPatchField<foam::vector<double> >::initEvaluate(bool) [6] #5 Foam::GeometricField<foam::vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate() [6] #6 Foam::tmp<foam::geometricfield<foam::vector<double >, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::surfaceIntegrate<foam::vector<double> >(Foam::GeometricField<foam::vector<double>, Foam::fvPatchField, Foam::surfaceMesh> const&) [6] #7 Foam::tmp<foam::geometricfield<foam::vector<double >, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::surfaceIntegrate<foam::vector<double> >(Foam::tmp<foam::geometricfield<foam::vector<doub le>, Foam::fvPatchField, Foam::surfaceMesh> > const&) [6] #8 Foam::fv::gaussDivScheme<foam::tensor<double> >::fvcDiv(Foam::GeometricField<foam::tensor<double >, Foam::fvPatchField, Foam::volMesh> const&) [6] #9 Foam::tmp<foam::geometricfield<foam::innerproduct< foam::vector<double>, Foam::Tensor<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::div<foam::tensor<double> >(Foam::GeometricField<foam::tensor<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) [6] #10 Foam::tmp<foam::geometricfield<foam::innerproduct< foam::vector<double>, Foam::Tensor<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::div<foam::tensor<double> >(Foam::GeometricField<foam::tensor<double>, Foam::fvPatchField, Foam::volMesh> const&) [6] #11 Foam::tmp<foam::geometricfield<foam::innerproduct< foam::vector<double>, Foam::Tensor<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::div<foam::tensor<double> >(Foam::tmp<foam::geometricfield<foam::tensor<doub le>, Foam::fvPatchField, Foam::volMesh> > const&) [6] #12 Foam::turbulenceModels::kEpsilon::divR(Foam::Geome tricField<foam::vector<double> , Foam::fvPatchField, Foam::volMesh>&) const [6] #13 main [6] #14 __libc_start_main [6] #15 __gxx_personality_v0 at ../sysdeps/x86_64/elf/start.S:116 ----------------------------------------------------------------------------- One of the processes started by mpirun has exited with a nonzero exit code. This typically indicates that the process finished in error. If your process did not finish in error, be sure to include a "return 0" or "exit(0)" in your C code before exiting the application. PID 24663 failed on node n3 (172.28.0.120) due to signal 8. ----------------------------------------------------------------------------- |
July 4, 2007, 14:45 |
Can you post the full checkMes
#14 |
Rep Power: 21 |
Can you post the full checkMesh output here?
July 5, 2007, 05:51 |
I think that explains it all.
#15 |
Rep Power: 21 |
I think that explains it all. Even if you ignored the warnings, you have a serious error to rectify. Despite your observation concerning no problems when running in serial mode, my suggestion is to work toward solving that error and trying again. In either case, with a mesh so bad (i.e. high non-orthogonality and skewness), I doubt the solvers will do a decent job and/or how meaningful your final CFD solution will be. I have read in the forums and it is also my personal experience that OpenFOAM does a very nice job at parallel given a decent interconnect and case setup (which includes mesh definitions/discretizations et al.). If all you want to do is check your parallel setup, then try one of the example cases (e.g. dambreak). Hope that helps.
OpenFOAM 141 parallel results infiniband vs gigabit vs SMP | msrinath80 | OpenFOAM Running, Solving & CFD | 10 | November 30, 2007 19:11 |
OpenFOAM 13 AMD quadcore parallel results | msrinath80 | OpenFOAM Running, Solving & CFD | 1 | November 11, 2007 00:23 |
Problem using OpenFOAM in parallel | skabilan | OpenFOAM Running, Solving & CFD | 6 | October 13, 2007 00:47 |
OpenFOAM 14 stock version parallel bug | msrinath80 | OpenFOAM Bugs | 2 | May 30, 2007 15:47 |
OpenFOAM 14 Parallel build | mplongjr | OpenFOAM Installation | 3 | May 15, 2007 04:32 |
