MotionUy and DynamicMesh with OF14
Old   July 9, 2007, 09:04
Default Hello Community, I am tryin
bfa
Björn Fabritius
bfa is on a distinguished road
Hello Community,
I am trying to use automatic mesh motion with component laplacian solver and uniform diffusivity (for inner point motion).
I need to apply a non-uniform boundary motion to one of my walls, therefore I read motionUy from the dictionary and calculate a location-dependent motion velocity in y-direction. So far so good: The new motionUy values are written to the time directories as
value non-uniform List<scalar>
But the executed motion is somehow always uniform. i.e. instead of morphing into a sinus kind of shape, the whole boundary moves upwards.
How can that be? Is there anything I have to change in the laplacian motion solver?
Any hints would be welcome, I could as well send my source snippets and pointMotionU/cellMotionU files if neccessary.
Regards
Bjoern
bfa is offline   Reply With Quote
Old   July 9, 2007, 10:35
Default Hello again, I think I found
bfa
Björn Fabritius
Hello again,
I think I found a part of the problem:
In my application I read only cellMotionU, not pointMotionU with
volScalarField& cellMotionU =
const_cast<volscalarfield&>(objectRegistry::lookup Object<volscalarfield>("cellMo tionUy"));
then I update the cellMotion with
cellMotionU.boundaryField()[movingBottomID] ==
curMotionVel_ *
Foam::sin(5.0*M_PI*(boundaryPoints.component(vecto r::X)));
with curMotionVel_ being the amplitude of my motion dependant on simulation-time and boundaryPoints being a vectorField containing the face centres of my moving boundary. (As you can see, I want to describe a motion dependent on the x-coordinate).
When I now try to do the same with pointMotionU, namely
pointScalarField& ptMotionU =
const_cast<pointscalarfield&>(objectRegistry::look upObject<pointscalarfield>("po intMotionUy"));
I get loads of compilation errors concerning the datatype pointScalarField.
Any idea how to read the pointMotionUy values and change them similar to the cellMotionU? I thought the solver's volume-point-interpolator would do the trick for me, but I was wrong there.
Regards
Bjoern
Old   July 10, 2007, 07:52
Default Hmm, looks like I'm talking to
bfa
Björn Fabritius
Hmm, looks like I'm talking to myself mainly. But nevertheless I made some progress. i.e. I surrounded the problem and now make it lay down its weapons and give up.
I found out that changing the cellMotionU entry in the time directories is not sufficient, since the motionSolver (in my case laplacianFvMotionSolver) only reads the value from $CASE_ROOT/0 but never updates itself.
How can I tell the motionSolver to take the new (calculated) values for cellMotionU every timestep?
Thanks for your help,
Bjoern
How to upgrade OF14 to OF15 ivanyao OpenFOAM Installation 7 February 15, 2009 11:19
How can i run OF14 rshssh passwordless waynezw0618 OpenFOAM Installation 2 July 11, 2008 07:41
DynamicMesh not buils using icc 100 in sgi altix 4000 arkangel OpenFOAM Installation 0 October 24, 2007 10:40
PROBLEMS WITH cfdTools in OF14 leosding OpenFOAM Running, Solving & CFD 1 August 20, 2007 14:05
Some one help!!! Write Cp location for dynamicmesh Endee FLUENT 0 July 11, 2007 06:42
