July 27, 2007, 03:33 |
Hi everybody,
From icoFoam:
Thomas Jung
Rep Power: 17 |
Hi everybody,
From icoFoam: fvVectorMatrix UEqn ( fvm::ddt(U) + fvm::div(phi, U) - fvm::laplacian(nu, U) ); solve(UEqn == -fvc::grad(p)); // --- PISO loop for (int corr=0; corr<nCorr; corr++) { volScalarField rUA = 1.0/UEqn.A(); U = rUA*UEqn.H(); phi = (fvc::interpolate(U) & mesh.Sf()) + fvc::ddtPhiCorr(rUA, U, phi); adjustPhi(phi, U, p); for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++) { fvScalarMatrix pEqn ( fvm::laplacian(rUA, p) == fvc::div(phi) ); pEqn.setReference(pRefCell, pRefValue); pEqn.solve(); if (nonOrth == nNonOrthCorr) { phi -= pEqn.flux(); } } # include "continuityErrs.H" U -= rUA*fvc::grad(p); U.correctBoundaryConditions(); } Question: Inside the loop UEqn is not beeig re-build. Should rUA, or UEqn.A() and UEqn.H() not remain the same? Why then is this beein repeated all the time? volScalarField rUA = 1.0/UEqn.A(); U = rUA*UEqn.H(); Thank you very much for any hint! Thomas |
July 27, 2007, 03:52 |
hi,
you should search the f
Stephan Gerber
Rep Power: 17 |
hi,
you should search the forum - this question was already answered. greeting stephan |
July 27, 2007, 04:25 |
finally found it, sorry...
To
Thomas Jung
Rep Power: 17 |
To whom it may interest,too: By Hrvoje Jasak on Thursday, August 04, 2005 - 12:40 pm: Edit Post Not so stupid: UEqn.H() uses the current value of U to evaluate itself and that's where the predicted value gets into the game. |
July 27, 2007, 06:02 |
hi,
no problem - nice if i
Stephan Gerber
Rep Power: 17 |
hi,
no problem - nice if i could help you ... greetings stephan |
PISO Details | Dr B.M. Smith (Smith) | OpenFOAM Running, Solving & CFD | 17 | November 17, 2009 11:31 |
Understanding k from kepsilon | markh83 | OpenFOAM Post-Processing | 3 | December 5, 2008 03:42 |
Incompressible boussiesq flow pressure BC piso and continuity problems | tehache | OpenFOAM Running, Solving & CFD | 4 | November 6, 2008 03:08 |
LUSGS understanding | Gustavo | Main CFD Forum | 0 | February 14, 2007 10:12 |
Understanding implemented PISO | stephan | OpenFOAM Running, Solving & CFD | 0 | January 28, 2006 11:11 |
