Mesh is ok but no convergence
Old   July 25, 2007, 08:46
Default Hello, Im computing in Simp
hoochie
Im computing in SimpleFoam the flowcase of an object in a wind tunnel. The mesh is a structured one and checkMesh tells me its perfect. Im working with the k- Epsilon realizable- turbulence. After running potentialFoam the given flow for the timestep "0" looks great, so my boundary conditions might be ok too.
My problem is, even with upwind- descritisation and turbulence turned off it isn't converging and I have no idea why.
So I set the relaxation factors step by step down to:
p 0.1
U 0.2
k 0.2
Epsilon 0.2
but with no effect. Does anyone of you have a clue what could be the problem? Or does anyone had a similar problem and solved it in past?
I would be happy for some hints, thank you
RW
Old   July 26, 2007, 11:57
Default Hi RW, I use simpleFoam too
lam
Hoang-Lam
lam is on a distinguished road
Hi RW,
I use simpleFoam too (turbulence off, but in laminar)
And i have a "better" convergence when I increase the relaxation factors:
U -> 0.8
p -> 0.3
But maybe, we'are not in the same case, because I do not use k-epsilon.
Cheers,
Lam
lam is offline   Reply With Quote
Old   July 28, 2007, 08:07
Default Hi Lam, thank you for your
hoochie
Hi Lam,
thank you for your answer, I will check out, if this may help me too.
greetings
RW
[Other] Mixed mesh nonothogonalcorr and the convergence sven82 OpenFOAM Meshing & Mesh Conversion 0 December 10, 2008 10:59
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
mesh quality and convergence Ed Schaub FLUENT 2 April 24, 2006 11:55
Convergence on skewed mesh ales FLUENT 5 April 18, 2001 10:00
Convergence problem when ustructured mesh is used. SangJin Ryu Siemens 3 October 5, 2000 21:26
