Functions available in boundaryMesh
Old   August 2, 2007, 06:19
Default Hello, I have been trying t
David Mulholland
irishdave is on a distinguished road
I have been trying to look through the source to see what I can find in relation to how to navigate the geometry of a patch. I want to be able to perform an operation on the inlet which requires knowledge of the face owner neighbour relations for cells on the inlet. I need the relations for those that are in the cross section of cells at the inlet.
I saw in a source code that someone else had written the ability to do the following:
const fvPatchVectorField& centre = mesh.C().boundaryField()[inletPatchID];
I have so far been unable to find where in the source documentation this comes from and I have also been unable to do similar. Does anyone know where this is documented or if there is a similar idea for mesh.owners(), mesh.neighbours(), mesh.Sf() and mesh.V()? Those are the values I need for the cells in the cross section at the inlet in order to achieve my aim.
Thanks
David
irishdave is offline   Reply With Quote
Old   August 2, 2007, 06:31
Default I have just been looking throu
David Mulholland
I have just been looking through the source code, looking at the fvPatch class and it seems to have what I am looking for. Either by using the patchSlice method on a list from the mesh or by using it's inbuilt functions assuming faceCells() returns something to do with the face - cell relations from which I could figure out owner and neighbour relations.
Sadly I can't see how to generate a reference for fvPatch of the inlet.
Thanks
David
Old   August 3, 2007, 12:49
Default Problem solved.
David Mulholland
Problem solved.
functions in UDF Lucy FLUENT 4 April 14, 2011 17:41
Functions evgenii OpenFOAM Pre-Processing 1 December 5, 2005 14:43
Wall functions? Pr Main CFD Forum 7 April 8, 2004 07:15
damping functions(wall functions) Pr Main CFD Forum 0 March 22, 2004 03:17
control functions mzi Main CFD Forum 0 March 27, 2003 00:50
