Source term
Old   June 23, 2006, 11:35
Default I fell some trouble to impleme
chris book
chris1980 is on a distinguished road
I fell some trouble to implement a scalar transport eqn with the following source term:
C1*[grad(Xi)]^2 - C2*epsilon/k * rho * Xi
C1,C2: constants
epsilon: turbulent dissipation
k: turbulent kinetic energy
Xi: scalar variable
How do I have to implement this FOAM?
chris1980 is offline   Reply With Quote
Old   June 23, 2006, 13:52
Default the main problem is the realis
chris book
the main problem is the realistation of the squared gradient [grad(Xi)]^2
I have tried to do this like:
volScalarField gradXiVar2 = fvc::grad(XiVar) &
solve
- fvm::Sp(...,gradXiVar2)
but the following error occurs:
--> FOAM FATAL ERROR : incompatible fields for operation
[XiVar] - [(grad(XiVar)&grad(XiVar))]
How can I realise this squared gradient term?
Old   June 23, 2006, 13:54
Default ups there is type volScalar
chris book
ups there is type
volScalarField gradXiVar2 = fvc::grad(XiVar) & fvc::grad(XiVar)
Old   June 23, 2006, 14:25
Default You've just for the the wrong
Hrvoje Jasak
You've just for the the wrong way around:
In fvm::Sp, first put the multiplier and then the field you're solving for. Also, you seem to be confused by the meaning of things a bit:
- first things first: C1*[grad(Xi)]^2
C1*magSqr(grad(Xi)). Done.
- C1*[grad(Xi)]^2 is always positive, which makes it a source. Putting it into Sp will just harm your matrix structure. Thus, just leave it as a plain old field in the source
- if you want to make C2*epsilon/k * rho * Xi, please tell me which variable you want to make it implicit in. In other words, what equation are you solving where this appears as the source term. I will assume you're solving for Xi: in this case, the Sp term would read:
fvc::Sp(C2*epsilon/k*rho, Xi)
Note that C2*epsilon/k*rho, is always positive and the minus in front of it makes this a sink term, so there's a point in making this an Sp. As you can see, the multiplier comes first and then the field (Xi) that you're solving for.
Enjoy,
Hrv
Hrvoje Jasak
Old   June 24, 2006, 03:08
Default thanks Hrv! just to make su
chris book
thanks Hrv!
just to make sure I get you right:
I want to solve a Xi-eqn and the problem is to implement the following source terms
C1*[grad(XXi)]^2 - C2*Xi
the first term I already know from the XXi-Eqn so I think I can simply write
C1*magSqr(fvc::grad(XXi))
the second term is always a sink (as you already mentioned) so an implicit formulation will advance the diagonal dominance of my matrix so you write
but why not fvm::Sp(C2*epsilon/k*rho, Xi) ???
Am I on the right way?
Old   June 24, 2006, 05:20
Default Sorry, my fault: it should (of
Hrvoje Jasak
Sorry, my fault: it should (of course) be fvm::Sp(C2*epsilon/k*rho, Xi)
Hrv
Hrvoje Jasak
Old   August 14, 2007, 08:08
Default Hi everybody When i add a s
Marhamat Zeinali
marhamat is on a distinguished road
Hi everybody
When i add a source term (grad(Fi)) to momentum equation in icoFoam solver i get the below error
Where:
Gravity defined as Gravity [0 1 -2 0 0 0 0] 9.81
and:
volScalarField Fi = Gravity.value() * mesh.C().component(1) ;
fvVectorMatrix UEqn
fvm::ddt(U)
+ fvm::div(phi, U)
- fvm::laplacian(nu, U)
solve(UEqn == fvc::grad(Fi)-fvc::grad(p));
SOURCE_DIR=.
SOURCE=icoFoam.C ; g++ -m32 -Dlinux -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-30 -I/marhamat/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude -I/marhamat/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -pthread -c $SOURCE -o Make/linuxGcc4DPOpt/icoFoam.o
icoFoam.C: In function 'int main(int, char**)':
icoFoam.C:66: error: 'Fi' was not declared in this scope
make: *** [Make/linuxGcc4DPOpt/icoFoam.o] Error 1
What is the matter?
Thanks alot
Marhamat
marhamat is offline   Reply With Quote
Old   August 14, 2007, 11:49
Default The definition of Fi is inside
Alberto Passalacqua
The definition of Fi is inside braces {}, so it's not accessible when it's used in the solve line.
Check where Fi is defined.
Regards,
A.
Alberto Passalacqua
Old   August 25, 2007, 05:18
Default Hello everybody After running
morteza
morteza is on a distinguished road
Hello everybody
After running the new icoFoam solver that changed by adding grad(Fi) as a source term , the vorticity magnitude increased with opposite of my expection .
I used inlet and outlet for inlet&outlet boundries and other boundries are symmetryplane
You can see the vorticitymag before and after of adding grad(Fi).I explaned Fi in my last message in this page.
Do you think i get correct result?
An How i can decrease the vorticity magnitude?
Have a nice weekend
Marhamat
morteza is offline   Reply With Quote
Old   August 25, 2007, 08:18
Default Hi guys I send the above mes
Marhamat Zeinali
Hi guys
I send the above message with my friend.
So anything is right.
sorry for disturbing you
Marhamat
Old   August 27, 2007, 07:04
Default Ideas are welcome.(-: Thanks
  #11
Marhamat Zeinali
Thanks alot
Source term Jony FLUENT 3 January 17, 2009 18:44
Source term mayur FLUENT 0 August 10, 2004 14:23
source term zwdi FLUENT 2 May 26, 2004 11:34
the source term neil CFX 10 July 15, 2002 18:10
source term fouzi FLUENT 0 April 13, 2000 12:56
