Temperature distribution in a solid
Old   August 29, 2007, 03:18
Default Hallo! I am a new OpenFoam-
Michael Krobath
michael_krobath is on a distinguished road
Hallo!
I am a new OpenFoam-User and just doing my first steps.
Beside some other things I need to calculate the temperature distribution in a solid block, which consists of some different materials. The thermal conductivity of these materials depend on the temperature. Boundary conditions are mostly a temperature, a heat transfer coeffizient/ambient temperatur or heat flux. I would need the temperature in steady and unsteady state.
Up to now, I used Fluent/Gambit for those problems but in future we won't.
Creation of the mesh is no problem. But how can I setup this problem in OpenFoam? Do you know any tutorial or test case, which I can work thru to learn, how to solve such a problem?
Thanks in advance
Michael
michael_krobath is offline   Reply With Quote
Old   August 29, 2007, 03:38
Default Hello Michael Try the follo
Prashant Ojha
prashant24983 is on a distinguished road
Hello Michael
Try the following link, you can also find a case file and required solver information here.
http://openfoamwiki.net/index.php/HeatTransfer
Just look through the case file and the solver.
Cheers!
Prashant
prashant24983 is offline   Reply With Quote
Old   August 29, 2007, 07:59
Default Hi! As I understand it, he
Assistant Moderator
Bernhard Gschaider
Hi!
As I understand it, he doesn't need the fluid part (except for the boundary conditions) - all parts are solid. So on one hand that solver would be too complex, on the other hand it is too simple because it still uses a constant thermal conductivity.
The "simplest" way would be to modify laplacianFoam to use a field instead of a constant for the "diffusion coefficient"/thermal conductivity.
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   August 29, 2007, 08:12
Default Thanks for your replys. Be
Michael Krobath
Bernhard, you are right. My problem is "only" to calculate the temperature distribution within the solid (no fluid take part).
But, I have different solid materials, with different thermal conductivities and they are (in worst scenarios) all temperature dependent.
Michael
temperature distribution in a plate with 2 metals Amir Khodabandeh FLUENT 1 March 16, 2007 03:51
HELP temp distribution on solid when dip in fluid MANOJ FLUENT 0 August 22, 2005 03:53
how to adjust solid distribution hx FLUENT 0 June 11, 2005 21:13
Linear Temperature Distribution Kathir FLUENT 0 July 16, 2004 10:33
Temperature Distribution on a circuit board Blackadder Main CFD Forum 1 March 27, 2003 12:32
