September 11, 2007, 21:13 |
I'm trying to simulate the mot
Srinath Madhavan (a.k.a pUl|)
Rep Power: 21 |
I'm trying to simulate the motion of a single air bubble through a column of water.
When the simulation starts, the log file reads: MULES: Solving for gamma Liquid phase volume fraction = 0.0013888 Min(gamma) = 0 Max(gamma) = 1 MULES: Solving for gamma After about 0.8 seconds (with time-step size of approximately 0.0001, Max Co = 0.15): MULES: Solving for gamma Liquid phase volume fraction = 0.0013888 Min(gamma) = -2.7143954e-24 Max(gamma) = 0.9551684 MULES: Solving for gamma Why does the maximum gamma in the domain decrease to 0.95? Surely there are significant regions in the domain where only pure water is present. If I'm mistaken can someone explain what Max(gamma) represents. Thanks! |
September 11, 2007, 22:24 |
Did you plot the result
Pei-Ying Hsieh
Rep Power: 18 |
Did you plot the results to check if the results are reasonable? Do you have surface tension turned on? pei |
September 11, 2007, 22:28 |
Yup, results look reasonable.
Rep Power: 21 |
Yup, results look reasonable. Surface tension is defined in transportProperties. How is it turned on?
September 13, 2007, 12:37 |
Any luck? If not, you
Pei-Ying Hsieh
Rep Power: 18 |
Any luck? If not, you can send me your case. I will take a look at it when I have the spare time. pei |
September 13, 2007, 14:33 |
Hi Pei,
I am running a slig
Rep Power: 21 |
Hi Pei,
I am running a slightly different case with a very well refined mesh. Now Max(gamma) is at 0.99999993 which I believe is not a problem. However should it decrease to something like 0.9 or 0.95 I will package the case and email it to you. Thanks for your help. |
December 9, 2013, 02:19 |
#6 | |
Nazanin
Rep Power: 13 |
Do you found your problem?I have a problem like you.... |
Mass Conservation | Prabhas | FLUENT | 0 | December 5, 2006 02:15 |
about conservation of mass | timur | Phoenics | 7 | February 15, 2006 10:29 |
Mass Conservation in LES | Jaswant | Main CFD Forum | 8 | July 4, 2005 23:32 |
Mass conservation | Diego Nogueira | Main CFD Forum | 1 | July 30, 2004 16:50 |
Question on Sediment Mass Conservation Scheme | Wen Long | Main CFD Forum | 0 | July 6, 2004 16:45 |
