Electronics cooling question
Old   September 18, 2007, 16:40
Default I would like to simulate heat
connclark
I would like to simulate heat transfer from circuit board components to the air inside the case, then to the case, and finally to the air outside the case.
I think I would need to use buoyantFoam but I have no idea how to deal with the heat transfer from the air to the case or heat flow through the case.
Any suggestions?
Old   September 18, 2007, 17:20
Default Hi, look at: http://www.cf
sradl's Avatar
Stefan Radl
sradl is on a distinguished road
look at:
http://www.cfd-online.com/cgi-bin/Op...=3807#POST3807
You need basically for each phase (2 x air and solid) an own mesh. So things become a little complicated...
You can also use some kind of modified boundary condition. The choices you have are documented at:
http://openfoamwiki.net/index.php/HeatTransfer
br
Stefan Radl
sradl is offline   Reply With Quote
help, required to simulate cooling of electronics plain FLUENT 0 October 7, 2006 22:22
What is the best electronics cooling package? Alan Main CFD Forum 0 September 4, 2006 12:35
FLUENT application (electronics cooling with PCM) Win Win Maw FLUENT 1 January 30, 2006 06:10
CFD Package Evaluation for Electronics Cooling n.pascarella Main CFD Forum 14 June 14, 1999 22:22
Electronics Cooling Russell King Main CFD Forum 13 September 25, 1998 23:47
