DICPCG solver in interFoam
Old   September 20, 2007, 06:05
Default Dear, I am trying to run a
m9819348's Avatar
Ries Bouwman
m9819348 is on a distinguished road
Send a message via Skype™ to m9819348
Dear,
I am trying to run a simple case of a liquid bubble moving in another liquid.
I use OpenFoam 1.4.1
The DICPCG solver needs about 20 to 300 iterations, right from the start and this does not diminish. I use a very small time step (1e-7).
For the solver settings, I used the standard settings of the DamBreak case.
My model is simply a pipe system (3D) through which the main fluid flows, including a small pipe inside the larger pipe where the bubbles are injected.
Is it normal that the solver needs so many iterations per time step?
Dr. Ries Bouwman
Business Development
ESI Group
004369917171525
@riesbouwman
m9819348 is offline   Reply With Quote
Old   September 20, 2007, 14:10
Default First make sure that your cour
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
First make sure that your courant number does not exceed 0.2. Next how bad/good is your mesh? Finally, if everything is going fine except for simulation time, then try using the GAMG solver as opposed to the DICPCG solver.
msrinath80 is offline   Reply With Quote
InterFoam MULES solver jaswi OpenFOAM Running, Solving & CFD 6 June 21, 2022 09:46
About interFoam solver zou_mo OpenFOAM Running, Solving & CFD 129 December 2, 2019 06:39
Solver BICCG DILUPBiCG DICPCG mamaly60 OpenFOAM Running, Solving & CFD 2 October 31, 2007 08:03
About interfoam solver qiu OpenFOAM Running, Solving & CFD 0 May 6, 2007 23:48
Need documentation for interFOAM solver mer OpenFOAM Running, Solving & CFD 5 May 31, 2006 13:22
