Alternative diesel fuel
Old   September 19, 2007, 10:00
Default The tutorial concerning diesel
Tomislav Sencic
tsencic is on a distinguished road
The tutorial concerning diesel is done with heptane C7H16. I would like to use different hidrocarbons, for example C12H26. I know I have to change the species, the reactions and the coeffs in chemkin/chem.inp and the nasa polinomials in chemkin/term.dat. I supose also in constant/thermophysicalproperties i should ad some coeffs but I do not know how.
What do I have to change to use a different fuel then those mentioned in chemkin/therm.dat?
tsencic is offline   Reply With Quote
Old   September 21, 2007, 05:25
Default I found the IDEA fuel in the s
Tomislav Sencic
I found the IDEA fuel in the src/thermophysicalModels/liquids directory, but I do not know how to use it.
What do I have to do in order to use the IDEA fuel?
Old   September 21, 2007, 05:44
Default Hi. Tomislav You can use th
nishio
Hi. Tomislav
You can use the fuel by changing the liquidFuelComponents in constant/thermophysicalProperties.
Old   September 21, 2007, 06:59
Default Thanks. I tried but I receive
Tomislav Sencic
Thanks.
I tried but I receive again some errors.
Do I have to change the reactions and the species in chem.inp? Do I have to put the reactions for both the components of IDEA (C10H7-CH3 and N-C10H22(DECANE)? Where can I find the reaction coefficients?
Do I have to change something in chemkin/thermo.dat?
Old   September 21, 2007, 08:08
Default I tried to use C14H30. I chang
Tomislav Sencic
I tried to use C14H30. I changed chem.inp with the reaction
2C14H30 + 43O2 => 28CO2 + 30H2O
but I get
--> FOAM FATAL ERROR : Elemental imbalance in H in reaction
irreversibleArrheniusReaction
2C14H30^0.25 + 43O2^1.5 = 28CO2 + 30H2O
(2.81171e+06 0 7940.36)
on line 10
What is the reason?
Old   September 21, 2007, 09:05
Default Hi Tomislav, Try with the
Tommaso Lucchini
lucchini is on a distinguished road
Hi Tomislav,
Try with the following
C14H30 + 21.5 O2 => 14CO2 + 15H2O
and see what happens.
bye
lucchini is offline   Reply With Quote
Old   September 21, 2007, 09:13
Default Hello, Shouldn't you be usi
Guido Adriaensen
guido_adriaensen is on a distinguished road
Shouldn't you be using:
C14H30 + 21 O2 => 14 CO2 + 15 H2O
The O was in imbalance.
Guido
guido_adriaensen is offline   Reply With Quote
Old   September 21, 2007, 09:15
Default Sorry, Never mind my post :
Guido Adriaensen
Sorry,
Never mind my post :-) Thought there was something else written there.
Tommaso's post was correct, sorry again.
Old   September 21, 2007, 09:45
Default Tomislav, it seems to be so
Tommaso Lucchini
Tomislav,
it seems to be something related to the coefficients:
FORD / C14H30 0.25 /
FORD / O2 1.5 /
Try to investigate what they mean.
Old   September 21, 2007, 09:55
Default Yes, I just left them from the
Tomislav Sencic
Yes, I just left them from the tutorial for C7H16. I 'll try to investigate.
Anyway, thanks
Old   November 8, 2011, 04:53
Abhishek
Abhishekd18 is on a distinguished road
Hi everyone,
I am trying to run sprayFoam. I am using C12H26 and have added the specie in therm.dat and reaction in chem.inp.
ELEMENTS
H O C N AR
END
SPECIE
C12H26 O2 N2 CO2 H2O
END
REACTIONS
2C12H26 + 37O2 => 24CO2 + 26H2O 3.00E+5 0.0 15780.0! 1
FORD / C12H26 0.75 /
FORD / O2 1.5 /
END
I am getting following error.
--> FOAM FATAL ERROR: Elemental imbalance in H in reaction irreversibleArrheniusReaction 2C12H26^0.75 + 37O2^1.5 = 24CO2 + 26H2O on line 10 From function chemkinReader::addReaction in file chemistryReaders/chemkinReader/chemkinReader.C at line 782. FOAM exiting
Where is the imbalance?
Abhishekd18 is offline   Reply With Quote
Old   February 16, 2012, 14:25
Roberto Torelli
RobertoTorelli is on a distinguished road
Hi everyone!
I have a question for Abhishekd18 (and also for everyone who could help me). Did you solve the problem of the reaction imbalance? I have the same problem and I also tried to divide by 2 all the reaction coefficients in order to have a unitary coefficient for the dodecane, but still nothing... Furthermore I have updated my therm.dat with the correct janaf coefficients, so I think the problem is related only to the chem.imp file.
I hope you could help me and thanks in advance! :-)
Roberto
RobertoTorelli is offline   Reply With Quote
Old   August 12, 2013, 15:51
Juan Manuel Mompó Laborda
juanma is on a distinguished road
Originally Posted by Abhishekd18 View Post
Hi everyone,
ELEMENTS
H O C N AR
END
SPECIE
END
REACTIONS
FORD / O2 1.5 /
END
Hi Abhishekd,
Where did you get the JANAF coefficients for C12H26 from? Could you please share them?
Thanks!
Juanma
juanma is offline   Reply With Quote
Diesel fuel combustion Marek CFX 1 November 30, 2008 14:39
diesel fuel injection part Nozzle/Elment/D.valveVE Michael weng Main CFD Forum 1 April 4, 2006 22:46
Fuel Modelling in Diesel Engines, what's truth Jo Siemens 0 August 18, 2004 14:47
Spray and combustion model for alternative fuel Torn Main CFD Forum 3 November 12, 2003 05:05
Alternative to Gambit chris FLUENT 1 October 16, 2002 01:53
