Oodles and more
Old   July 6, 2005, 12:14
Default Hi, I am trying to add an equ
Radu Mustata
r2d2 is on a distinguished road
I am trying to add an equation to oodles and then run it for a "cold jet" simulation. The equation would be for a non-reacting scalar and itīs done in a similar way as "ftEqn.H" of XiFoam. I will breafly describe what Iīve done ("mixf", it`s the name of my variable):
firstly: mixfEqn.H reads:
tmp<fv::convectionscheme<scalar> > mvConvection
fv::convectionScheme<scalar>::New
mesh,
phi,
mesh.divScheme("div(phi,mixf_2)")
solve
fvm::ddt(mixf)
+ mvConvection->fvmDiv(phi, mixf)
- fvm::laplacian(sgsModel->nuEff(), mixf)
I added in "createAverages.H"
volScalarField* mixfMeanPtr;
if (nAveragingStepsFile.good())
Info<< "Creating field mixfMean\n" << endl;
mixfMeanPtr = new volScalarField
IOobject
"mixfMean",
runTime.timeName(),
mesh,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
mesh
else
IOobject
"mixfMean",
runTime.timeName(),
mesh,
IOobject::NO_READ,
mixf
volScalarField& mixfMean = *mixfMeanPtr;
Then in "calculateAverages.H" I added:
mixfMean = nm1Coeff*mixfMean + nCoeff*mixf;
and in "createFields.H"
Info<< "Reading field mixf\n" << endl;
volScalarField mixf
IOobject
"mixf",
runTime.timeName(),
mesh,
mesh
now, at runtime, in the 0 directory I added the "mixf" file with all the definitions of patch values and all that
I run the case in parallel using LAM and it seems to run fine, for as long as I left it running Co did not go over 0.5. The trouble that I have is that at finalising the program I get a message like:
--> FOAM FATAL ERROR : NO_READ specified for read-constructor of object Umean of class IOobject
Function: regIOobject::readStream(const word&)
in file: db/regIOobject/regIOobjectRead.C at line: 53.
FOAM parallel run aborting
...and this Umean can be something else like mixf_0, or pmean or mixfmean ...with the same error. Then, of course (I guess) when I want to reconstructPar the simulation I get (e.g. in the aforementioned error case):
Time = 0.0005
Reconstructing FV fields
Reconstructing volScalarFields
mixf_0
nuSgs
epsilonMean
k
mixfMean
--> FOAM FATAL IO ERROR : cannot open file
file: /mnt/store1/radu/OpenFOAM/radu-1.1/run/oodles2/coldjet/processor9/0.0005/mixfMea n at line 0.
in file: db/regIOobject/regIOobjectRead.C at line: 68.
FOAM exiting
Am I missing something? Help...please!
Cheers,
Radu
r2d2 is offline   Reply With Quote
Old   July 6, 2005, 12:21
Default Because mixf is not part of a
henry is on a distinguished road
Because mixf is not part of a thermodynamic or other coupled system there is no need to use multivariate discretisation for it. So instead of
use
fvm::iv(phi, mixf)
and then you don't need
mesh,
phi,
henry is offline   Reply With Quote
Old   July 6, 2005, 12:22
Default Sorry I mean fvm::div(p
Sorry I mean
fvm::div(phi, mixf)
Old   July 6, 2005, 12:29
Default Thanks, I will try this and
Radu Mustata
Thanks,
I will try this and see how it goes. Will keep
the fvScheme for it like this, then...
div(phi,mixf) Gauss Gamma201 1;
Radu
Old   July 6, 2005, 12:43
Default Did what you said...got the sa
Radu Mustata
Did what you said...got the same, as in now:
--> FOAM FATAL ERROR : NO_READ specified for read-constructor of object R of class IOobject
I MUST be doing something wrong...
Old   July 6, 2005, 12:48
Default To get rid of this error messa
To get rid of this error message you must specify MUST_READ rather than NO_READ for your constructors of objects you are reading.
Old   July 7, 2005, 08:39
Default Did that in "createAverages.H"
Radu Mustata
Did that in "createAverages.H" and now seems fine. Not that I understand it very well, though: I mean at startup if I donīt have anything I thought I should be putting:
IOobject
"mixfMean",
runTime.timeName(),
mesh,
IOobject::NO_READ,
mixf
rather than:
IOobject
"mixfMean",
runTime.timeName(),
mesh,
mixf
Thanks anyway.
Radu
Old   July 7, 2005, 09:02
Default Yes that is a copy-constructor
Yes that is a copy-constructor not a read-constructor so you should use IOobject::NO_READ for it.
Old   September 14, 2005, 13:50
Default I tried version 1.2. I played
Ralph
ralph is on a distinguished road
I tried version 1.2. I played around with "oodles" (problem on 3 processors) and noticed, that it has about 25% less performance, compared to version 1.1.
Is this a common attribute or is this my specific problem?
Iīve seen, that there is some new implementation of "phi"-calculation in "oodles". May this be the cause?
Ralph
ralph is offline   Reply With Quote
Old   July 23, 2007, 05:02
Default hi, I feel bad to ask you thi
Cedric DUPRAT
cedric_duprat is on a distinguished road
hi,
I feel bad to ask you this question with all the explication before but;
I also have a FOAM FATAL ERROR mistake after ...lot's of iterations (which is hurtful):
NO_READ specified for read-constructor of object phi_0.
The problem is that I can't find the phi_0 IOobject in oodles (in createAverages.H) someone know where it is implement ? Or someone can just help me there ?
Thank you,
Cedric
cedric_duprat is offline   Reply With Quote
Old   September 23, 2007, 02:54
Default Hi When i add body force (
  #11
Marhamat Zeinali
marhamat is on a distinguished road
Hi
When i add body force (F) to oodles and icoFoam solvers it seems that vorticity generation in the test case using with icoFoam is more than oodles.
My test case is a channel that it sides are symmetryplane and inlet velocity is zero.
And F is exponential subject that acts on the geometry center and affect limited domain for several time step.
Any hint?
Thanks in advance
Marhamat
marhamat is offline   Reply With Quote
Coefficienct in the oodles loneboard OpenFOAM Running, Solving & CFD 4 March 12, 2009 22:18
A question on DES oodles ivan_cozza OpenFOAM Running, Solving & CFD 2 November 17, 2008 10:33
Oodles vs turbFoam rolando OpenFOAM Running, Solving & CFD 9 June 4, 2007 06:42
Parallel oodles sriharsha OpenFOAM Running, Solving & CFD 0 December 27, 2006 18:25
Parallel oodles sriharsha OpenFOAM Running, Solving & CFD 0 December 27, 2006 18:21
