Time is always zero
Old   September 24, 2007, 17:04
Default Hello OpenFoam Users, I hav
Kian Mehravaran
kian is on a distinguished road
I have 1.4.1, compiled with single precision.
I noticed that when I use a deltaT lower than 1.0E-05, it is basically regarded as zero. In other words, time is always zero!
I checked the deltaT.value() in the code (sonicFoam), and it contains the correct value.
Any advice is appreciated,
Kian
kian is offline   Reply With Quote
Old   September 25, 2007, 00:16
Default I compiled with double precisi
Kian Mehravaran
I compiled with double precision, and the problem is gone now.
Old   September 25, 2007, 14:53
Default See Time.C around line 620.
Mattijs Janssens
mattijs is on a distinguished road
The problem in single precision is that there are only 6 significant digits. There is some truncation in operator++ to reach time 0 exactly which is probably too strict for your case.
mattijs is offline   Reply With Quote
Old   September 26, 2007, 11:15
Default In the code segment you pointe
Kian Mehravaran
In the code segment you pointed to (the ++ operator), time is set to
value() + deltaT_
then it is forced to zero if its value is less than 10*SMALL or 1E-5, perhaps for aesthetics?!
I can't understand why it is not forced to zero in double precisions, when your deltaT is say 1E-8?
Old   September 26, 2007, 11:24
Default OK, I was wrong about SMALL be
Kian Mehravaran
OK, I was wrong about SMALL being 1E-6 in double precision, that value is for single precision.
The actual value of SMALL is 1E-15 in dp.
I wanted to get rid of that if statement, but I'm going to stick with the dp version instead, since it is better tested.
Is there a way to write the time step size, time a may FLUENT 6 November 22, 2009 12:52
Time step in time explicit solver Simon FLUENT 1 August 5, 2009 11:32
Long time CHT transient simulation time step.... JP CFX 0 May 9, 2008 04:36
autosave at flow time with adaptive time stepping Ybes FLUENT 0 November 3, 2007 13:32
Relation of computational time step with real time Salman Main CFD Forum 2 August 3, 2005 15:13
