Convergence issues with a highly curved laminar flow
Old   September 21, 2007, 17:26
Default Hello Ning, It could mean t
Philippose Rajan
philippose will become famous soon enough
Hello Ning,
It could mean that your flow is actually not laminar, but turbulent.... due to which the laminar solver is not able to converge.
Your mesh seems to be quite ok....
Maybe you can try a turbulent simulation using simpleFoam and see if that converges.
Enjoy!
Philippose
philippose is offline   Reply With Quote
Old   September 21, 2007, 21:56
Default Hi Philippose: Thank you fo
Ning Yang
nzy102 is on a distinguished road
Hi Philippose:
Thank you for your input. The Re number for my case is only around 1000. I don't see any possibility of turbulent flows.
Ning
nzy102 is offline   Reply With Quote
Old   September 22, 2007, 05:45
Default Hello again Ning, Since I d
Philippose Rajan
Hello again Ning,
Since I dont know anything about the case you are trying to simulate, I need to be cautious about this....
I think a Reynolds Number of 1000 is in a region where you need to start worrying about the flow already being turbulent, or being somewhere in the transition region.
The typical Reynolds Number of 2300 as the limit for laminar flow that one keeps reading about, is for a very specific case, of a smooth straight pipe.
There are systems where you can have a critical Reynolds Number as low as 500....
Usually, if the Reynolds Number is "very high", you can easily say that the flow is turbulent, or if the Reynolds Number is "very low", you can call the flow laminar... but in the region that you are in..... one needs to be quite careful.
Since you specified that you are working on highly curved 3D flow... with more than one input and more than one output (implying that there will be flow mixing, and dividing...etc....etc...), I think you need to consider the possibility of turbulence in your system.
Have a nice day!
Philippose
Old   September 22, 2007, 23:04
Default Thanks philippose. I think the
Ning Yang
Thanks philippose. I think the flow in my case is more like in a transitional state. It is not possible to use the current available low-Re two equation or other turbulent models to study this type of flow. There is probably some unsteadiness with the flow. But the problem is that I got good converged results using first-order upwind for steady laminar flow. Somehow it doesn't converge for the second order schemes. Anybody here can give me some hints? I am really stuck with this problem for a while. Thank you.
Ning
Old   September 26, 2007, 23:52
Default Hi Philippose: I tried some
Ning Yang
Hi Philippose:
I tried some low-Re turbulence models (lienLescchz and liencubic). I got the same thing. It converges well for the first-oder upwind but not for second-order schemes. The geometry I am using is pretty complex, and first-order scheme apparently is not accurate enough, not sure how to deal with this case now.
Multiphase flow and convergence issues Erik FLUENT 1 July 13, 2009 18:08
Convergence issues Zachary Sorensen FLUENT 3 February 23, 2007 14:07
RSTM convergence issues nazario Main CFD Forum 0 June 23, 2006 08:23
Convergence issues derick FLUENT 4 August 22, 2005 16:09
Convergence issues Riaan FLUENT 4 January 13, 2005 21:34
