September 27, 2007, 10:05 |
Hi everybody.
I'm trying to s
joao carneiro
Rep Power: 17 |
Hi everybody.
I'm trying to solve a simple case to test the twoPhaseEulerFoam solver. The problem is that of the demixing of bubbles flowing through a channel dispersed in water. But I have some problem. After a couple of time steps, reversed flow occurs at the outlet boundary. I assume there is some problem with the BC. Is there anybody who had a similar problem? I set the boundary condition as follows: Ua boundaryField { inlet { type fixedValue; value nonuniform List<vector> 18 ( (0 0 0) (0.0319305 0 0) (0.0635875 0 0) (0.0943479 0 0) (0.123419 0 0) (0.1498 0 0) (0.172243 0 0) (0.189193 0 0) (0.19873 0 0) (0.19873 0 0) (0.189193 0 0) (0.172243 0 0) (0.1498 0 0) (0.123419 0 0) (0.0943479 0 0) (0.0635875 0 0) (0.0319305 0 0) (7.21645e-17 0 0) ) ; } outlet { type zeroGradient; } lowerWall { type slip; } upperwall { type slip; } defaultFaces { type empty; } } Ub boundaryField { inlet { type fixedValue; value nonuniform List<vector> 18 ( (0 0 0) (0.0319305 0 0) (0.0635875 0 0) (0.0943479 0 0) (0.123419 0 0) (0.1498 0 0) (0.172243 0 0) (0.189193 0 0) (0.19873 0 0) (0.19873 0 0) (0.189193 0 0) (0.172243 0 0) (0.1498 0 0) (0.123419 0 0) (0.0943479 0 0) (0.0635875 0 0) (0.0319305 0 0) (7.21645e-17 0 0) ) ; } outlet { type zeroGradient; } lowerWall { type fixedValue; value uniform (0 0 0); } upperwall { type fixedValue; value uniform (0 0 0); } defaultFaces { type empty; } } alpha boundaryField { inlet { type fixedValue; value uniform 0.0257; } outlet { type zeroGradient; } lowerWall { type zeroGradient; } upperwall { type zeroGradient; } defaultFaces { type empty; } } I also tried to change the BC to "calculated" but unfortunately with no success. I get the following message: --> FOAM FATAL IO ERROR : keyword value is undefined in dictionary "/nfs/home/lee/OpenFOAM/lee-1.4.1/run/tutorials/twoPhaseEulerFoam/channelFlow_in ternal/0/alpha::outlet" file: /nfs/home/lee/OpenFOAM/lee-1.4.1/run/tutorials/twoPhaseEulerFoam/channelFlow_int ernal/0/alpha::outlet from line 42 to line 42. From function dictionary::lookupEntry(const word& keyword) const in file db/dictionary/dictionary.C at line 146. FOAM exiting Thanks for any hint. Joao. |
Channel flow DNS | alberto | OpenFOAM Running, Solving & CFD | 20 | February 17, 2016 18:26 |
Channel flow DNS | Abhinav | Main CFD Forum | 1 | April 11, 2013 07:37 |
maintain a constant flow rate in channel flow ? | Lewis | Main CFD Forum | 2 | September 28, 2010 12:35 |
LES channel flow | Hadi | FLUENT | 0 | September 20, 2007 06:15 |
BC for 2d channel flow | khan | Main CFD Forum | 1 | February 1, 2007 00:26 |
